90-94 Front Bumper Grille Headlight Support Bracket
[SOLVED] 90-94 Front Bumper Grille Headlight Support Bracket
Hello,
I have a question regarding the front-end headlight and bumper support bracket, highlighted here in red:
More specifically, I am wondering about the locations of where the sides of this bracket bolt on to the car, and how.
I already know the following:
- For the 3 central mounting points on the bracket, each have 2 bolts that attach to the frame.
- This bracket can not be removed entirely without first removing the headlights and bumper from the car.
I have attached photos to aid in the understanding of my question.
Thanks!
[SOLVED]
I was able to figure out this problem, with the aid of a section from the Repair Manual, sent to me.
The bolts located on each side of the bracket attach to the fenders:
[DISCLAIMER: These photos are not mine, and are from Lextreme.com and Ebay]
Thanks!
[SOLVED]
https://www.clublexus.com/forums/ls-...n-1-ls400.html
The pictures don't quite show it, must be to the fender?
Thanks, Dicer. I was thinking the same, but it's still not quite clear. The visible bolt, connected to the frame in one of your photos, is for the fender.
I've been searching for a while, but it seems that this component is rarely mentioned.
EDIT: Solution found. Looks like I will need to remove the bumper to get to these bolts. [See initial post]
You were right, Dicer. Thanks
1HRDLEX
IS - 1st Gen (2001-2005)
01-10-04 06:29 PM
