99 GS300 from Taiwan
#32
Wheels ordered from Yahoo Japan,
AME Shallen XS-20
20*8.5 +36 front / 20*9.5 +11 rear
Working on this IS200 climate control had ruined my whole weekend.
Turned out to be the clear piece inside that guided light to the button. Just had natural aging to them causing darker than normal outputs.
I make my own LEDs for button mods. Generally 470Ohm for 12v supplies is a safe bet.
AME Shallen XS-20
#35
January 2016
Had some bogging issues, likely air mixture related, cleaned MAF sensor but discovered it was the resonator box on the intake tube.
Also stocked up on a spare set of headlight for retrofit later.
Installed the Greddy Grex Big 6 Pot front BBK and some generic Taiwanese made Mid 6 Pot rears.
Installed the 30mm shortened knuckles.
Finally got the AME Shallen XS-20 from Japan. 20*8.5 +36 / 20*9.5 +12
Had to pull the rear in order to tuck.
#36
It seems like you got the push button start to work with all of the Off, ACC, and Start features which is awesome because I haven't seen that before. Did you use an IS350 button with the wire harness attached to it and splice those wires into the car? Did you have to wire something into the stop light switch where you have to press the brake to start it?
#38
There are wiring points you need to connect per the instruction. Brake switch is one of them. However, it also comes with remote start.
#39
I'm looking to sell the rear calipers and buy the 4 pot for rears.
Definitely a must especially for those who likes to go fast. No point in going fast if you can't stop in time.
#42
#43
They have an extra strip on the side. for you to tuck into things. The space between the leather and the wood trim was the best location to stuff it for more of an oem look.
#45
There's a high voltage inverter for them. The way I have it wired up is with ignition on and door/dome light trigger. So even if the car is off they will still turn on when doors are opened.
