Mini or Low Profile Mini Fuses?
Old 01-26-17, 03:52 PM
peteharvey
peteharvey's Avatar
Default Mini or Low Profile Mini Fuses?
Does anyone know if the 3IS uses mini or low profile mini fuses?
Or does it use Lexus exclusive fuses?
Old 01-26-17, 04:14 PM
Answer
Answer's Avatar
Low profile mini!
available anywhere!
peteharvey (01-26-17)
Old 01-26-17, 05:07 PM
peteharvey
peteharvey's Avatar
Thanks for that Answer.
I have to get a low profile mini fuse remover to remove the fuse, and then plug in a low profile mini fuse tap/piggy backs to the constant and switched power fuses to hardwire my dash cam.
Old 01-26-17, 05:18 PM
Answer
Answer's Avatar
That's exactly what I did!
Only downside, the fuse box cover won't fit anymore!
Old 01-26-17, 06:50 PM
peteharvey
peteharvey's Avatar
Is it possible to use some of the empty sockets, then purchase two separate 5 Amp fuse, and wrap the yellow & red wires to the positive fuse end, and then plug those two fuses in - then we can close with the fuse cover?
Just depends if those empty sockets have constant or switched current.
Old 01-26-17, 07:13 PM
Answer
Answer's Avatar
From what I remember, there was not empty sockets that were satisfying the power needs, so those add-a-fuse are a must. And since they are bigger, the cover won't fit. Anyways, I just threw mine in the glove box!
LocoStrnge (04-09-23)
Old 01-26-17, 07:20 PM
peteharvey
peteharvey's Avatar
I was thinking of piggybacking the Hazard Warning Flasher fuse to get 12v constant, and the Radio fuse to get switched 12v.
Which fuses did you piggyback?
Old 01-26-17, 07:22 PM
Answer
Answer's Avatar
Holy ****, can't remember! I'd have to take a look to tell you!
Old 01-26-17, 07:23 PM
peteharvey
peteharvey's Avatar
Old 01-26-17, 07:24 PM
peteharvey
peteharvey's Avatar
I'm thinking of using Haz & Radio.
Old 01-26-17, 07:25 PM
Answer
Answer's Avatar
I'll take a pic of them tomorrow!
Old 01-26-17, 07:26 PM
peteharvey
peteharvey's Avatar
Did you use the bolt in the second photo to ground/earth the negative black wire to your chassis, to return the current to the black negative terminal of the battery?
Old 01-27-17, 04:21 AM
Answer
Answer's Avatar
far from being the best photo, but should help you! The best I could do in this morning rush!
peteharvey (01-27-17)
Old 01-27-17, 01:42 PM
peteharvey
peteharvey's Avatar
Well, it looks like you have tapped into:
1) The Hazard Warning Flasher blue fuse @ 15A for your constant 12V power supply, and
2) The Ignition No 1 red fuse @ 10A for your accessories Acc ignition switched 12V power supply.
The two new fuses for your dash cam are 3 Amps each.
You have returned the current via the black wire, by earthing/grounding it to your hexagonal metal chassis screw at the bottom of the photo, as I originally suspected.
You have the exact same empty single and dual channel slots as me.
Thanks for sharing Answer...
Old 01-31-17, 06:28 PM
tamerica
tamerica's Avatar
Does any know if the USB ports have a fuse? Only one of my USB ports are working.
Quick Reply: Mini or Low Profile Mini Fuses?
