MY '13 GS head unit volume button stuck
Old 02-10-17, 04:57 PM
kawaiiGS
kawaiiGS's Avatar
Default MY '13 GS head unit volume button stuck
Hi guys! Seems like my pwr volume switch has sunken in and broke.. do you guys know how I can fix it without having to shell out for a new head unit? Thanks in advanced!
Old 02-10-17, 05:24 PM
DaSyce
DaSyce's Avatar
Just curious, how hard of a push resulted in causing this sort of damage?
Old 02-10-17, 05:26 PM
kawaiiGS
kawaiiGS's Avatar
Ironically I rarely use the **** since I use the volume keys on the steering wheel mostly. It just so happened to be stuck in. The previous owner loves music as the **** had some scratches when I got the car lol
Old 02-10-17, 05:29 PM
yardie876
yardie876's Avatar
This happened to another owner a few months back. I don't remember what the solution was. Search search search! It's here somewhere.
Old 02-10-17, 05:34 PM
bclexus
bclexus's Avatar
Received 2,218 Likes on 1,587 Posts
HERE it is...
DP03 (02-10-17)
Old 02-10-17, 05:39 PM
kawaiiGS
kawaiiGS's Avatar
Originally Posted by bclexus
HERE it is...
i remember doing a search bbeforeand came up emptyy at the time. Thanks though! Man hopefully I can do it later this weekend. Cali rain is no fun
Old 02-12-17, 11:45 PM
avs20
avs20's Avatar
Same thing happened to my radio from previous owner. Lexus fixed it under warranty for me as well!
Old 02-13-17, 03:29 PM
GreyGS350
GreyGS350's Avatar
Same thing happen to my car a month ago. Lexus wanted to replace the whole unit for 1100 i said u guys are crazy!! I tried taking it out my self but couldnt so i took it to a local Audio place n they pull it out right away n i bought a replacement buttom at the dealer for 3 bucks. I also have a few scratches i did when i was trying to pull out the bottom from a small screwdriver.
Old 02-14-17, 05:54 AM
DaSyce
DaSyce's Avatar
Any chance you guys took pictures..
Sounds like this issue is more common, and likely to repeat.
Old 12-05-17, 07:55 PM
opmredwing
opmredwing's Avatar
Default Sunken in volume button
Fellas, just wanted to weigh in on my '13 volume button issue. Didn't press it very hard at all and it sunk all the way in flush. Took it to dealer today and they said they are going to try and pull the button out but it will most likely scratch up the button so they said if they can they will replace just the button. If problem persists, they will have to replace the whole head unit.... so glad I bought that extended warranty from carmax! Have had a squeaky steering wheel pulley, fast running clock and now the radio all covered under my warranty so far.
Old 12-06-17, 07:20 AM
CottageChz
CottageChz's Avatar
Glad I never push my volume **** for anything. This is crazy!
Old 12-26-17, 02:50 AM
EyeKutr
EyeKutr's Avatar
https://www.clublexus.com/forums/gs-...shed-in-2.html
Old 07-17-18, 05:42 PM
jlmbnd
jlmbnd's Avatar
I ran into this problem today and wound up on this forum looking for solutions. I was able to pull the **** back out using 2 popsicle sticks and a pair of channel locks. You may need to shave the popsicle sticks down with a razor blade but should be able to get one in the top and bottom. I was careful not to squeeze too hard so as not to damage the metal and the **** came right out. I hope this method works for others. (note that channel lock images below were taken after the **** was pulled out)
The following 2 users liked this post by jlmbnd:
Im2bz2p345 (06-20-22), jonathancl (07-18-18)
Old 08-14-18, 11:31 AM
Polo708
Polo708's Avatar
OMG just happened to me too... well, just now noticed it on my tune dial. Guess I’ll try to pull it out 😕
Old 08-30-18, 07:01 AM
Petrolhead
Petrolhead's Avatar
****FiX*****
I simply took a flat clothing button and looped about 10 loops of thread thru it (Fishing line would do as well, fewer loops). I used a glue gun to glue the button onto the radio button. Let it cool for about 2 minutes, and simply slowly pulled out the radio button.
Once the button was off I was able peel of any glue without any residue and push it back on to the normal position.
It's been fine since I did the repair about 3 months ago.
jonathancl (08-30-18)
Quick Reply: MY '13 GS head unit volume button stuck
