Help key fob reprogram
Old 02-16-17, 07:45 AM
lexus9894
lexus9894's Avatar
Exclamation Help key fob reprogram
I have a 1998 lexus ls400. I can't get the key to program to the car. I might have read the wrong post can some one tell me how to do this on my own.
Old 02-16-17, 09:16 AM
billydpowe
billydpowe's Avatar
look and read.., I am assuming you have a working key, if not go to dealer...
File Type: doc
File Type: doc
Old 02-16-17, 11:46 AM
saleenssc
saleenssc's Avatar
Please let us know if you get your key to work. I have a 98 as well. I was able to program the key to start the car, however i was unable to get the lock/unlock buttons to work. I followed the instructions exactly as described in the previous post. but still no luck. Eventually i just gave up. Please share your experience.
thanks
Old 02-16-17, 08:11 PM
Yamae
Yamae's Avatar
Can you recognize the Posistor?
thanks
It is the often case for aged cars with aged door lock/unlock actuators to fail the fobbing due to the reason that PTC Thermistors/Posistors inside of the door lock actuator motors heat up too much and the lock/unlock speed is slower and it exceed the time limit of the fobbing cycle. You need to check the condition of the actuator before the fobbing. It should be OK to repeat lock and unlock many times.
Every time I failed to fob, I had to do something to the actuator which works slower. Just cleaning the motor or replacing the motor made it possible to fob as is written in the manual.
02Legend
02-07-23 06:12 AM
mk416
IS F (2008-2014)
08-12-19 05:08 AM
Chriszilla
Performance & Maintenance
06-01-17 11:14 AM
Reef13
07-02-15 08:54 AM
Busha
12-22-11 08:49 PM
Quick Reply: Help key fob reprogram
