Wheel width/offset/size and tire fitment Q&A thread
#886
2002 GS430 lowered 1.5" on Tein static springs and Bilstein shocks. I'm looking at some rims with the following specs:
20 x 9 Front / +32 offset / 245/35/20 tire
20x 10.5 rear / +45 offset / 275/30/20 tire
Will these fit as is? Or will it require fender modifications due to rubbing?
Thanks for the help!
#888
Stock gs430 rear factory air ride and stock front struts.
xxr 521 wheels are on sale tomrrow,
18x8.5 +25 front
18x10 +12 rear
will this wheel size be to aggressive? I know I will roll my fenders, and run a 245 or 255 up front, and I'd like to run a 265 or bigger in the rear,? What do y'all think
18x8.5 +25 front
18x10 +12 rear
#894
im looking to purchase a set of es2 varrstoen rims 18x9.5 front and 18x10.5 rear. what size tires should i get for fronts and rears??? im on stock suspensions but going to lower the car with godspeed coilovers. can i still drive the car with the es2 rims with tires in stock suspension??? will i need spacers also? i know i have to roll the fenders...
#896
Fitment Question
I ended up buying these for my 2001 gs300. My fenders are rolled and I'd like to go pretty low. What tire sizes would be best? Do I need to shave the rears? New to the GS world. Thanks
#897
I have 2 pairs of rear IS350 8.5" wheels and I am looking to run a square setup so I can rotate my tires. Will a 265/40/18 fit in the front or should I go 255/40/18 all around?
Edit: To clarify, I am on stock SportDesign suspension
#898
The 255/40 is probably okay at your height. 265/40 is definitely too big, just in general. I would consider that oversized even by width, for a 8.5" wheel, but it's too tall as well. 265/40-18 is an inch taller than the factory 17" tire size and 1/4" taller than the largest OEM size (215/60-16). 245/40-18 is the ideal size for what you are doing, that's why so many people use it and it's the default +1 size for this vehicle in tire fitment guides.
#899
Please help
I've read through this forum as well as some others in the LS400 BBK. I have an 03 GS running on Bremmer Kraft BR07 19x9.5 +35 all around (245/40/19), LS 4-piston calipers w/ .5" spacers, and Front RCA's. Everything else is stock and I'd like to keep it that way as much as possible. I'm planning to pass this car down to my son, therefore I don't have a desire to overly modify the vehicle or spend a lot of $$. The spacers are causing my alignment to be out of whack and resulting in premature tire wear. I thought about abandoning the brakes and reverting back to stock, but I think it would be easier and more cost effective to get wheels that fit properly.
I really need help finding the best fitting wheels. I really want to stay w/ 19's and I'd like to go as wide as possible. A few particulars to mention: I don't want staggered wheels, I can't honesty afford custom wheels, and I don't want spacers anymore. According to my research, LS400 uses +38 offset for oem fitment, but once I plug in the additional width I get lost. Please help
I think these wheels might work ok: http://www.avantgardewheels.com/m359.php
They come in 19x9 and 19x10. It seems like a sweet idea to run 19x10 all around w/ +38, but I really don't know.
