IS 200 turbo orangevirus flash question
Old 03-15-17, 08:06 PM
Is200tnc
Is200tnc's Avatar
Default IS 200 turbo orangevirus flash question
I have a 2016 Is200t and have been looking at different tuners for my car. I am considering the VRtuner but recently came across this site and wanted to see if anyone has used this or if anyone has any information about it besides what is listed on the site.
https://www.ovtuned.com/collections/...e-package-2015
Lexus IS200T Remote Tuning ECU and Transmission Tune Package 2016+
Looks legit and they say that their flash will get rid of the dreaded 30percent power till 4k rpm. Anyone tried this yet?
Old 03-15-17, 08:49 PM
gbgary
gbgary's Avatar
https://www.clublexus.com/forums/per...200t-tune.html
Sheddy (03-16-17)
Old 03-15-17, 08:52 PM
Is200tnc
Is200tnc's Avatar
And that hyperlink is supposed to tell me what? No being a smart @ss just don't know what you are trying to infer. I see on the link there are tunes being done.
Old 03-16-17, 08:28 AM
Sheddy
Sheddy's Avatar
That thread contains a lot of information on performance tunes that members and myself have tested and reviewed.
Old 03-16-17, 10:55 AM
E46CT
E46CT's Avatar
Received 2,177 Likes on 1,634 Posts
Still curious maybe even a bit skeptical about the 30% thing. How does Lexus claim full 258 lbs of torque is made at below 2k rpm (I think 1,450?) if the throttle is limited to 30%? Either the 30% thing is false, or Lexus is falsely advertising (even worse).
Any thoughts, tuner bros?
Old 03-16-17, 11:36 AM
Sheddy
Sheddy's Avatar
TORQUE @ RPM*
258 lb-ft @ 1,650–4,400
Old 03-16-17, 12:56 PM
E46CT
E46CT's Avatar
so how does it make full torque below the supposed 3,000 minimum rpm required for full throttle?
full torque available at 30% throttle?
Old 03-16-17, 01:36 PM
Sheddy
Sheddy's Avatar
I made peak torque after 3K on stock and tuned. I can't ensure that the 30% claim is true or not but another ECU flash tuner (TTI Motorsports) said that there was a delay in throttle as well.
Old 03-17-17, 07:29 AM
cbus
cbus's Avatar
The tune is still in development as per the 'IS200t tune' thread. I will be purchasing it when it's out. By then, there should be a 93oct variant of it (I believe the current one is 91oct). I'll be making a thread detailing everything.
Old 03-17-17, 08:10 AM
MasonGrey
MasonGrey's Avatar
It's not the best proof, but I did post this photo way back from when the alpha tune. It's the most concrete evidence I have of showing the throttle limitation. Notice how the 2nd graph has a bizarre fall-off between 3000 and 4000?
Old 03-20-17, 07:35 AM
SubieChik
SubieChik's Avatar
It is currently available on the Orange Virus Tuning website. You can either get the tune by itself or as a package with a transmission tune.
OP I cannot wait to save up money and get this myself. I have heard some negative things about the VR Tuning version....I would not recommend it personally.
Old 03-20-17, 08:04 AM
gbgary
gbgary's Avatar
i don't see the tune only option...just the package.
Old 03-20-17, 08:08 AM
zcon
zcon's Avatar
after looking at that data log again, its almost as if the ecu has a calculated load and when it hits 100% engine load it modulates Throttle Position to keep it at their preferred 100%load. It would be nice to see what would happen if we could manually hold the throttle body open, I imagine this one is electronic. I mean in the middle of what I imagine is a 100% WOT you are only getting 100%TP during spool or loading of the engine. How does the engine hold boost? Does it peak and taper off or does it stay flat? that dip from 3-4k looks almost as if the transmission is down shifting,because look at the second pull that dip is not there, but im just speculating I dont know whats actually going on during this log. I'm more interested in not getting 100% throttle through out the whole pull.
Old 03-20-17, 08:38 AM
SubieChik
SubieChik's Avatar
I asked one of the employees about it on the Lexus FB page......if I remember correctly he told me it is available but it may not be on the website.
gbgary (03-20-17)
Old 03-20-17, 11:15 AM
cbus
cbus's Avatar
I've heard the tune is still in development. MasonGrey on here is the guinea pig IS200t owner working with OVTuned.
Quick Reply: IS 200 turbo orangevirus flash question
