Crack in Exhaust Manifold...
#106
I remember hearing the starter is between the header and the motor and the headers must come off to replace it, I'm also a bit curious about his question, I can't smell exhaust fumes from mine yet but the noise has gotten a bit annoying.
#107
i couldn't smell exhaust fumes on mine either but the noise got louder over the year i owned the car, i couldn't handle the noise anymore even with my joe z exhaust on so i took it in to get it fixed with my warranty.
#108
I can only hear it at idle really with my exhaust, it will eventually get PPEs but not until I see a power loss or exhaust smell. Seems like some have put some serious miles on the cracked headers without any issues.
#111
Breathing in exhaust fumes is a really bad thing and people can either pass out or die if driving long enough. This should be a recall and we should start a class action because it seems that most Lexus ISF cars have the same or similar cracks in the exhaust..
#112
So this is the case happen to my car that I have posted the question. The exhaust gas smell very strong with CO which is extremely dangerous like poison gas in the cabin. I have to open the windows in order to breath ! it's that serious man. My car already passed the warranty at 99k miles now. I don't know if Lexus can cover this issue?
#115
Same on the 3SGTE as well, my mr2 developed an exhaust manifold leak but its common on that motor too. Same spot every single time, so it has to be a Toyota thing on their performance based motors. Because I've had to do a new manifold gasket 2x on my mr2 since owning it for 8 years.
#117
If I'm not mistaken a set of OEM headers from the dealership will run more than aftermarket headers. At that point you're just better off going aftermarket. As they're obviously made better and provide more power. Also, removing and installing headers is quite the task. Something you want to do only once, which is why most don't even bother repairing the stock units.
#118
#120
-Mike
