What did you do to your SC today?
#6646
After finishing working on my kids Chicken "turbocoop"
I was tired looking at my spare wheel tub, and I don't like word tub in my car so I had to cut the ugly biotch out of my sc400
took me 10 min to cut it and 35 min to clean it up mask it and spray it.
I have a sheet of aluminum/ rubber seal will be cut and bolted up that's next
Now looking at the exhaust pipes and how tooth pick puney they are, I'm just thinking of just unbolting it completely after the first center muffler and go single axleback dual tip chop
#6648
They came with bolts, rather than those cheap bendy things. So I actually took off the rubber, and drilled small holes thru the pedals so they're fixed into place securely.
I've had 'em for a few years now; never came loose. Highly recommend!
#6651
Upgraded Twin GT28RS
-Compressor housing bore
-Wastegate bore
-Larger wastegate flaps installed
-Refurbished actuators
-Steel turbine shafts
-GT28RS turbine and compressor wheels installed
-Thermal coated
-Refreshed/rebuilt twins
Features
-Custom 3" Y-pipe w/temp sensor & wideband flange
-Custom 3" downpipe w/flex pipe
-Ebay AN oil drain/feed flange x2
-Ebay AN oil return flange
-Stainless steel braided high pressure oil feed x2
-Black and aqua braided AN oil return lines x2
#6654
-Wastegate bore
-Thermal coated
Features
#6655
pulled 30 inches of vacuum from the A/C system for 45 minutes, sealed it and checked it an hour later, still 30 inches so no big leaks. Filled it with 60 psi @ 90 degrees outside of R134 and felt very little cooling (max setting) coming out of vents, compressor kicked on at about 20 psi so I know its running quiet, Low side stays at 55-60 when running. I dont have a high side fitting for my manifold set. Could the drier be plugged up? I never changed any hardware besides the freon. system was never opened to air.
#6659
....... and replaced it with??????
