My first GX
Old 06-08-17, 04:25 PM
Acrad
Acrad's Avatar
Received 3,638 Likes on 2,383 Posts
Wow!!! Massively easy to change...thanks for tip about on the top. Took all of 10 minutes. This is a great mod if for nothing else than the utility aspect alone. These lights are so much brighter than the incandescent bulbs. I am more than happy with results. I think I could at least change the front diff and TC fluids with the illumination of these bulbs alone. :-)
FYI: 5K version of VLED listed above
Acrad is offline
Old 06-08-17, 08:59 PM
caesosa
caesosa's Avatar
Are these the the ones that are $18 per bulb???
caesosa is offline
Old 06-09-17, 04:52 AM
Acrad
Acrad's Avatar
Yeah expensive for an LED bulb but wanted something that had a higher chance of being reliable for an external application.
I probably should have gone with their "Long Life" version.
"As one of the few all-aluminum construction 194 bulbs on the market these are the highest output and safest available. For even higher reliability or continuously-on applications check out our Long Life version of this product."
Acrad is offline
Old 06-09-17, 09:54 AM
bbqsoup
bbqsoup's Avatar
Nice looks really bright.
I used Yorkim LEDs for the running boards and some 5k super bright generic in the interior and doors.
bbqsoup is offline
Old 06-11-17, 08:04 AM
Acrad
Acrad's Avatar
Ordered bulbs to complete rest of interior. I haven't received them yet but checking out light thread to see how things are removed.
The door assemblies are easy to remove but look to be a small PIA as you have to bend some metal clips that retain the stock bulb into assembly.
As suggested here.. DON'T open the map lights from this location. Fortunately I didn't break anything and read further in thread opposite front end sides is where you want to be. They open really easy from the forward sides. First picture is accurate... second one is a big no-no and you are apt to break something.
I just used the smallest plastic tool out of this HF trim kit.
https://www.harborfreight.com/5-piec...set-67021.html
Acrad is offline
Old 06-12-17, 09:27 PM
Dallasguy1
Dallasguy1's Avatar
Ordered 1 box of this today will post the pics once I have them on.
Dallasguy1 is offline
Old 06-13-17, 10:52 AM
bbqsoup
bbqsoup's Avatar
The metal retainer is there to hold the bulb in place, probably due to all the vibration when the door closes and opens. It's pretty easy to push it back. The issue I had with the door light is the housing of the LED light is a bit longer than the stock bulb so you have to push it harder to make it stay in the housing. Otherwise it may pop out. But once it fit in tight it wasn't moving anywhere.
bbqsoup is offline
Acrad (06-13-17)
Old 06-13-17, 10:53 AM
bbqsoup
bbqsoup's Avatar
Cool!...they are good LEDs
bbqsoup is offline
Old 06-15-17, 11:34 AM
Acrad
Acrad's Avatar
Swapped mine out yesterday..... the door lamps are pretty easy once you see how they are put together I just went with these VLEDs
http://www.vleds.com/shop-bulb-numbe.../194-1-ll.html
Doors could possibly be improved some with a 360 degree bulb but with the running board lamps being so bright not sure I am gonna bother. Really pleased with light output inside. I need to take a pic in dark. These easily fit in everything.
Acrad is offline
Old 06-21-17, 06:37 PM
Dallasguy1
Dallasguy1's Avatar
Swapped these yesterday and the best part about these they are not flickering. Great item guys.
Trijicon
GX - 2nd Gen (2010-2023)
13
11-27-19 03:00 PM
BHux78
GX - 1st Gen (2003-2009)
06-25-19 05:53 PM
bondguy
12-17-18 10:19 AM
KebCam
18
06-30-12 07:59 PM
Quick Reply: My first GX
