Audiocontrol lc2i question
Old 07-15-17, 04:24 PM
Robles84
Robles84's Avatar
Default Audiocontrol lc2i question
So I'm trying to install my sub set up the right way and bought this audio control line out converter.. It's rates at 400watts. But my amp is at 900 watts. Will this line out converter hold up? I will be pulling from the rear own sub power
Old 07-15-17, 06:10 PM
NL5
NL5's Avatar
I assume the amp you are adding after the conversion is 900 watts. In that case the wattage of your amp has absolutely nothing to do with the rating. That's input wattage from the factory amp which I believe is about 60 watts. You should be more than fine. I am using a cheap PAC converter without any problems. My subs are about as loud as they can be with the factory amp running the door speakers.
Robles84 (07-16-17)
Old 07-16-17, 06:16 AM
Robles84
Robles84's Avatar
Any suggestions for installation? My friend and I both never installed one before
Old 07-16-17, 06:21 AM
Robles84
Robles84's Avatar
Here is my set up....needs to be cleaned up still
Rockford Fosgate T10001 bd 1-Channel which is way under rated as most people know and my 2ohm dual voice coil 10in kicker
Robles84
05-18-17 05:32 PM
RXRider13
05-15-14 04:46 PM
bezee
08-07-05 06:23 PM
Dx3
11-28-04 04:42 PM
CoreY2K1
08-23-01 03:49 PM
Quick Reply: Audiocontrol lc2i question
