IS200t tune
Old 07-26-17, 04:59 AM
  #1306
cosmo1
cosmo1's Avatar
Nothing to see in your video but some bad welds... Will post up a pic later today..
Old 07-26-17, 05:40 AM
  #1307
Sheddy
Sheddy's Avatar
PM me for details!!! Brand new Burger Tuning piggyback with Data cable (to increase boost)
Old 07-26-17, 05:42 AM
  #1308
DaveGS4
Forum Administrator
DaveGS4's Avatar
Received 2,239 Likes on 1,358 Posts
Sheddy, just wanted to post and thank you for all the great research and info you've posted on this topic!
The following 2 users liked this post by DaveGS4:
Sheddy (07-26-17), WhyHateTho (04-12-18)
Old 07-26-17, 05:48 AM
  #1309
Sheddy
Sheddy's Avatar
Thanks Dave, Its my pleasure to learn and share with the community!
Old 07-26-17, 07:02 AM
  #1310
gbgary
gbgary's Avatar
Originally Posted by Sheddy
You should know! How's that been treating you? Ever raised the boost?
your bms prototype i ended up with has been good. like it a lot. haven't tried it in stage two yet. the link you sent me has several links of it's own and i'm not sure which to use. i'd try it if i knew.
Old 07-26-17, 07:21 AM
  #1311
Sheddy
Sheddy's Avatar
Glad to hear! I believe it is set at 3-4 PSI over stock in the default setting. If you were to do any bolt on modifications like a down pipe then i would suggest raising the boost, but if you are on a stock motor definitely keep it on the current setup. The full JB4 capabilities are not active for us, but we can change the PSI on the Boost Fail safe option or change to MAP 2 (6 PSI ) which is a more aggressive tune (bolt ons needed).
JB4 Download instructions .
Once you're connected chose MAP 1 and under User Adjustment set Boost Fail Safe to the desired PSI over stock, then click save.
Old 07-26-17, 07:44 AM
  #1312
gbgary
gbgary's Avatar
wow...cool! thanks! if i was going to do the downpipe i'd just do the flash.
Old 07-26-17, 07:54 AM
  #1313
Sheddy
Sheddy's Avatar
No problem! Yes the re-flash would utilize the bolt on's a lot better and also safer!
The BMS still hasn't been officially released, but he was able to make a couple units so there's only a handful of these out. You are one of the few
Old 07-26-17, 08:32 AM
  #1314
IS200TFOWL
IS200TFOWL's Avatar
Haha what a clown. Like i said look at the video description, we have 4 resonators
Old 07-26-17, 09:41 AM
  #1315
Nuke
Nuke's Avatar
take it easy bud maybe he just misunderstood the video
Old 07-26-17, 09:49 AM
  #1316
Sheddy
Sheddy's Avatar
There are only 2 catalytic converters on our cars and they are both on the down pipe.
Old 07-26-17, 10:19 AM
  #1317
cosmo1
cosmo1's Avatar
The secondary cats in which I'm referring to have a honeycomb material inside it just like the primary cats. A resonator has an open pathway with packing on the other side of perforated holes to absorb noise. When I have mine removed I will snap a pic of the inside...
Old 07-26-17, 10:58 AM
  #1318
Sheddy
Sheddy's Avatar
So you're referring to these as the secondary cats?
Has anyone removed these and took a picture of the inside? I thought these were resonators.
Old 07-26-17, 11:08 AM
  #1319
IS200TFOWL
IS200TFOWL's Avatar
I paid $80 to have them removed because I thought the same. The kid just doesn't want to listen. I'm 100% certain these are completely hollow, free-flowing resonators
Sheddy (07-26-17)
Old 07-26-17, 11:09 AM
  #1320
Nuke
Nuke's Avatar
just get an invidia mid pipe painless and its not very expensive plus its wider pipes and better flow
Quick Reply: IS200t tune
