Is this normal? - Small puddle after being parked
Hey everyone,
So I noticed that after I leave my car parked a while (mainly in parking garages) that I have a small puddle forming under the passenger front side. There doesn't appear to be much coloration other than a darkened wet patch, and no smell as far as I can tell. I suspect that it has something to do with the AC unit as I don't notice this in the wintertime. The car is consistently serviced at Lexus every 5k and nobody has ever mentioned anything remotely close to an oil leak so I haven't been too worried about it. Car drives just fine, smooth as butter without any odd noises from the engine. Torque/power all feels normal. Does anyone else notice this with their car? Mine is a 2012 460 AWD btw. Pic below.
Thanks for your help!
Yes it's very normal.
It's normal to have a small puddle of water after using the using the A/C.
Hopefully I'm not hijacking the thread too much: Today I accidentally left the car running in the garage with the garage door a bit too long and when I came in to shut off the car, the temp was 3/4 up. I didn't think too much about it but about 15 minutes later I walked out and there was a nice puddle of pink/red collected on the floor: the car leaked ant-freeze. I opened the hood and tried to find the leak to no avail. The water pump is bone dry, and I couldn't find any other sources for the leak other than maybe the small overflow hose coming from the coolant tank. Does the LS have a way of purging coolant when it's gotten too hot or the pressure has built too much in the system? I did an inspection of all the hoses for about 20 minutes and I couldn't find anything. I didn't have a bottle of Toyota coolant on hand so I didn't have any to fill the tank with and see if it keeps on leaking or not. Any ideas? If worst comes to worst I can always get it towed to the dealer but I'd rather avoid the $250 deductible if at all possible if it's a super easy fix like a hose (which it most likely is) or something. I'm planning to just add more coolant when I get to pick some up and try and pinpoint if it's leaking any further or not.
Jcham
09-06-09 05:20 PM
