Jimmy Mac 1999 SC300
#316
it can be a 180rwhp car and will still break quick . It is not a question of how much power . I have seen quite a number of +1000rwhp cars and are very reliable
^^^^ These !!!!
* Sticking with intended use of the car and built accordingly with all the right parts and by the right people , no reason why it won't be reliable.
Better move and enjoy that car more
^^^^ These !!!!
![Big Grin](https://www.clublexus.com/forums/images/smilies/biggrin.gif)
HRE 446 19 staggered Supra fitment. They are awesome. Currently cleaning them now. Amazing the quality of these wheels.
![](https://cimg0.ibsrv.net/gimg/www.clublexus.com-vbulletin/2000x1504/img_8089_35c369800eb5b7a30a95da719a8198196471af44.jpg)
Here's a sneak peak at a rear wheel before being cleaned. Stay tuned. More to come!
#317
Congrats on the new wheels!
It looks like it has a 180 degree valve stem on the barrel instead of a 90 degree. Make sure you change to 90 degree before mounting the wheels on your car. I screwed up a few years back and mounted a wheel with a 180 degree valve stem in the back, and it scratched a brand new bbk and blew out a tire/damaged a wheel because the valve stem was smacking the caliper while driving and snapped. It was really close, but barely cleared when test fitting and spinning the rim.
#319
Did you order hre bolts or an aftermarket company? If you're planning on splitting your wheels, then the torque spec is 22 ft lbs for M8x1.25 x 32mm bolts. The sealant is Dow Corning 733. I might have covered wheel building in my build thread, but I don't remember off the top of my head.
#320
That's good to hear. I didn't want to see you make the same mistake I did.
![](https://cimg5.ibsrv.net/gimg/www.clublexus.com-vbulletin/2000x1504/img_8102_177cb19a824be54dc210252ed2abb26bee4b5d9c.jpg)
![](https://cimg6.ibsrv.net/gimg/www.clublexus.com-vbulletin/2000x1504/img_8103_467b5ef9500280991b7d9a2410e3e47c3b67e8e6.jpg)
#321
I guess $650 isn't unreasonable because HRE hardware is grade 12.9 (plus they engrave them). If you want to see unreasonable, ARP nuts and bolts are $1,636.16 (consumer price) bolts are 787.84 and nuts are 848.32.
I wasn't sure if you were replacing them because of the rust. I had to do the same on mine to remove the surface rust, then I polished 160 bolts.
*Edit* I just noticed your picture looks like it says 10.9 on the bolts.
#322
![](https://cimg7.ibsrv.net/gimg/www.clublexus.com-vbulletin/2000x1504/img_8108_728fd97de8a833067351ec5ee3fb3624636850f0.jpg)
#323
![](https://cimg9.ibsrv.net/gimg/www.clublexus.com-vbulletin/2000x1504/img_8115_c2aa6c125f862f9b4dbd6b8b960f61247c147811.jpg)
Wow. This car STOPS. Can't wait to get the rear done. My HRE wheels are still being cleaned up but will be on next week. Also the rear 4 piston brembo brakes will go on next week. Here's a quick side shot. Someone wanted to see the z06 calipers with TT rears. Here ya go!
Blkexcoupe (09-09-17)
