RX300 Air Mode Servo removal made easy
Old 09-22-17, 01:22 PM
  #76
maxSteel
maxSteel's Avatar
Originally Posted by chenxingha
I am stuck at loosening the top screw pointed by the RED arrow in the photo. There is less than a finger space between the screw top and the 2 aluminium tubes which are running in parallel with no gap between the 2 tubes.
I need advice about getting this screw off.
Thank you.
I was able to get around the tubes. But if you can't, try:
Old 09-22-17, 02:17 PM
  #77
Lexmus
Lexmus's Avatar
See the first photo in post #61 of this thread
https://www.clublexus.com/forums/rx-...ml#post7613271
It shows a regular screwdriver engaged with the screw. Or use one of the screwdrivers like maxsteel posted.
Old 09-22-17, 04:24 PM
  #78
chenxingha
chenxingha's Avatar
Thank you both MaxSteel and Lexmus. I hand-made a "tool"
that worked for me to get the top screw loose. The tubes are so close to the screw top that I cannot even get a screw bit in, much less to use a ratchet. The hand-made device allow me to get to the screw from an angle. It took me about 10 minutes to loose the screw. Now the air mix servo is off and here are the photos of it:
As it can be seen, the internals are clean, nothing appears to be out of the ordinary. The motor drive shaft has very little room to escape the notch. I cleaned the track and contact springs and lay a coat of di-electric grease in place. Put pieces together - this time did not break any thing - and will reinstall it back tomorrow morning.
While looking for replacement parts, I found on RockAuto that the vehicle has 4 different servos! The main bodies are look-like, the differences are with the control arms.
https://www.rockauto.com/en/catalog/lexus,2000,rx300,3.0l+v6,1363586,heat+&+air+conditioning,heater+blend+door+actuator,10721
RockAuto lists them as (1) Blend Door Actuator (2) Mode Door control (3) Temperature Door control (4) Recirculation Door control. Based on the physical shape of the listed devices, the Mode Door control (2) is the mode servo (that I replaced a little while ago) and the Temperature Door control (3) is the air mix servo (that I am working on now). But where are the other 2 servos? In my case, based on the clean internals of the 2 servos (mode servo and air mix servo) that I had opened so far I suspect that the rapid-firing clicking noise comes from one of the other 2 servos that I don't know where they are.
Old 09-23-17, 07:17 AM
  #79
chenxingha
chenxingha's Avatar
I have reinstalled the air mix servo, still using the home-made tool to tighten the top screw. It appears that a proper procedure might be to remove the mode servo first, which would then give work space to remove/reinstall this top screw on the air mix servo. I think this ultra low profile screw driver on Amarzon could then add to the effort:
Amazon Amazon
While I was under the glove box area to reinstall the air mix servo, I looked around and identified the 3rd servo, which is on the side-top of the blower motor box. Here is a looking-up photo with a RED arrow pointing to this 3rd servo:
This servo is controlled by the fresh air/internal circulation button, and I believe this is the (4) Recirculation Door control (servo) in RockAuto's list in my previous post.
After reinstall the air mix servo, I turned on the engine and the rapid firing clicking noise was not present. It has not been present when I was ready (on my drive way and have the glove box removed) and really need it to help identifying the culprit - a cat and mouse game I suppose.
A question still remains: where is the 4th servo, the one that RockAuto labelled for Blend Door Actuator, (1) in its list?
Old 09-23-17, 07:30 AM
  #80
chenxingha
chenxingha's Avatar
I recall reading in the thread that someone was asking for the mode positions. The mode sequence on my vehicle goes in these steps: face -> face + foot -> foot -> foot + defrost -> (back to) face. While I was in there, here are the photos for the corresponding positions:
face
face + foot
foot
foot + defrost
The following 4 users liked this post by chenxingha:
JBell1 (08-13-23), Lexmus (09-23-17), maxSteel (09-23-17), rmk9785e (08-19-19)
Old 10-29-17, 01:17 PM
  #81
chenxingha
chenxingha's Avatar
Well, my cleaning work of the motor in the air mix servo box appears to worked - it has been about 3 months and the continuing "rapid-firing clicking" noise has not happened! Also important is the low level rumbling noise (sound of something continuously running from the center column) is no longer present.
My experience shows that, when rapid-firing clicking noise appears, the right path of fixing it is to remove the mode servo and then the air-mix servo; open both servo boxes and wipe clean the resistance wheels as well as the contacting arms; then apply a think coat of die-electric grease onto the wheels; carefully bend the contacting arms just slightly to ensure good contacts; then reassemble everything back - hopefully, not breaking any locking tabs that forces the box closed tightly. Then put the 2 servo units back in the reversed order.
In my case, none of the 2 servo units had any observable physical damages. The replacement of the mode servo unit might not be necessary - it was replaced at a time I did not know there are other servos. I now know the positions of 3 servos and there is indication that there may be a 4th servo somewhere.
Old 10-30-17, 01:12 PM
  #82
GroovyMom
GroovyMom's Avatar
Thanks everyone who has posted in this section! After 2 years with no heat in my 2002 Lexus RX300, I found and ordered a mix servo from Amazon. My 18 year old daughter, who can do anything once she sees it on you tube, took apart the "guts" after I removed the glove box. She replaced by dead mix servo with the new one and voila, we have heat!!!! Just in time for our cold spell. Thanks again folks!
(she also removed a full size sheet of paper from the blower motor which solved our noise problem.)
Old 11-06-17, 11:39 PM
  #83
Andro
Andro's Avatar
Hey all, I just got a 2001 RX300, I believe my mode servo is dead. I'm going to take it apart and see if I can fix it or replace it. Do you guys think this tool would work good for that hard to reach screw?
https://m.harborfreight.com/hand-tools/screwdrivers/33-piece-precision-screwdriver-set-93916.html
or this
https://m.harborfreight.com/8-piece-right-angle-screwdriver-92630.html
Old 11-08-17, 03:38 PM
  #84
maxSteel
maxSteel's Avatar
Probably the right angle would be more useful than that set. Or you could use one of the bits in that set in a vise grip
But this thread has other tool suggestions I'm sure.
Old 11-09-17, 08:03 AM
  #85
Andro
Andro's Avatar
Default Ummm
So um. Looks like the morons that fixed the mode servo before me only put in 1 screw, so good news is I don't have to fight that pesky 3rd screw! Yay! Bad news is, it's stuck in defrost/floor and doesn't want to wiggle out of the track. Any advice?
Edit: oops. Nevermind. I was looking in the wrong place. I do in fact get to fight the third scew. And I'm gonna lose. 😓
Well finally got it with some help. Tried to fix the worm screw a few times. It would work for a min then stop. Ended up just buying a new one. Got a lifetime warranty though! Also, noticed there is another servo up above this one, that doesn't open up all the way and lets some air leak out the vents when i change it to floor. It's good enough for now though. I got what I wanted done.
Old 10-06-18, 10:29 AM
  #86
chadmurrow
chadmurrow's Avatar
I wanted to say thanks to dimitrov for his recommendation. I just completed exactly what he recommended and it worked exactly like he said. It wasn't without a few curse words at the Recirculation Servo though. To remove this servo I had to remove a wiring harness bracket to reach the last screw. The new motor is strong enough to move the air mode servo into the face mode. Before the servo would move it out of this position but not back.
Also to address the pesky third screw, I used a 1/4 in drive with a 1/4 in socket with a Phillips head bit. This allowed me to remove and put the screw back in. I also removed the floor duct which gives you more room to work. This post saved me a couple of hundred dollars. Thanks for all that have contributed.
Old 12-22-18, 10:19 AM
  #87
simplecar
simplecar's Avatar
Unhappy Servo location
How many servos are there in the car, and where are they located? I want to know this because I plan on cleaning them all out today (12/22/2018) that way there's no issues with the HVAC system again. The heater stopped working last night when I drove the car, and I had to fiddle with the temperature **** to unstick it so it could at least get warm, which it did work temporarily.
Old 04-16-19, 06:17 PM
  #88
Phil01
Phil01's Avatar
Default Heater damper motors?
I now have a noise from the dash that is related to the climate control. It sounds like one of the damper motors. How do I access these and how many are there? I have been looking and they are not real expensive so I am wondering if it would be better to replace all of them.
Old 07-21-19, 11:18 AM
  #89
rmk9785e
rmk9785e's Avatar
Originally Posted by salimshah
Make sure you ordered the right servo
"mode" servo ... that controls the mode .. air to windshield, face or feet level.
" Mix" servo that controls hot/cold.
They are not interchangeable.
On installation make sure you move the lever manually to match the position of the servo arm. Do not try to move the arm manually.
Salim
Thank you for clarifying. I've removed the glove compartment and see only one servo. Where are the others located?
Beside regular clicking and clacking, my only other issue is that there is no cold air coming from the passenger side vents. What is the correct part number for the servo that controls where conditioned air is directed (the one I should be changing)?
Old 07-21-19, 05:51 PM
  #90
salimshah
Forum Moderator
salimshah's Avatar
Received 1,105 Likes on 994 Posts
Same thread post #75 #79
Salim
rmk9785e (07-22-19)
Quick Reply: RX300 Air Mode Servo removal made easy
