IS 500 Threads Conversations specifically about the 2022+ IS500 models.
IS-F Front Calipers
Old 04-08-23, 04:55 PM
Vendetta
Vendetta's Avatar
Default IS-F Front Calipers
Has anyone swapped IS-F 6-piston Front calipers onto the stock front rotors on our cars? I heard that it's a direct bolt on. If so, what do you need to do the swap and where did you get it?
Also what are your thoughts on it compared to converting the front brakes to RC-F/GS-F fronts?
Old 04-08-23, 05:17 PM
flowrider
flowrider's Avatar
Received 1,897 Likes on 1,338 Posts
You may find these two threads interesting:
https://www.clublexus.com/forums/is-...e-upgrade.html
https://www.clublexus.com/forums/is-...ig-brakes.html
Old 04-09-23, 09:31 PM
Vendetta
Vendetta's Avatar
I took a look at those threads and from what I read it seems that the RCF/GSF front brakes can bolt on our cars. For that swap you need: calipers, rotors, pads and brake lines. Also you need to either trim the dust shields or buy RC-F/GSF shields.
I haven't heard anyone talk about ISF calipers on our stock front rotors. From what I can tell you need calipers, pads and brake lines to do that front swap.
What I want to know is if there is any performance gain from ISF calipers and pads, or if it's just better to do the whole GSF/RC-F system.
Old 04-10-23, 04:40 AM
TipsyTonio
TipsyTonio's Avatar
Received 2,275 Likes on 1,046 Posts
All I can add is that it can be done. I recently watched a YouTube review comparing an IS F to an IS500 and the IS500 had swapped ISF calipers to the car. No details on what is needed though. I tried finding the link but I can’t find it now.
Old 04-10-23, 05:56 AM
cp2
cp2's Avatar
Quick answer is yes. Still have to shave some of the dust guard. Install is from older IS mk3 but same concept.
Old 04-10-23, 09:35 AM
89is500
9th Gear
89is500's Avatar
The IS500 in the video is mine. bolts right up, just need to bend or shave the dust shield a tiny bit. You can also use the existing brake lines.
I chose to do it for more brake pad options, and this upgrade is very cheap compared to the RCF caliper upgrade. I paid about $700 for both calipers from my local dealer.
The following 2 users liked this post by 89is500:
jororo (05-08-23), Racer00J (05-10-23)
Old 04-10-23, 09:39 AM
TipsyTonio
TipsyTonio's Avatar
Nice! Thanks for sharing. Do you have part numbers for everything you bought? Also is the stock rotor compatible or does it require different rotors? Thanks
The following 2 users liked this post by TipsyTonio:
89is500 (04-10-23), Bechtold (04-10-23)
89is500
9th Gear
89is500's Avatar
These are the part numbers:
47750-0W030
47730-0W030
The only other thing you need is a set of brake pads. The stock rotors are compatible.
Credit to 350phi who gave me all of this info.
The following 8 users liked this post by 89is500:
350phi (01-06-24), Bechtold (04-10-23), daily35 (10-30-23), FLXYLXY (11-29-23), gcmak (05-05-23), Racer00J (05-10-23), TipsyTonio (04-10-23), wthrman2 (04-11-23) and 3 others liked this post. (Show less...)
Old 04-10-23, 09:47 AM
89is500
9th Gear
89is500's Avatar
Here's the video comparing my car to an ISF:
The following 5 users liked this post by 89is500:
350phi (04-10-23), arentz07 (05-08-23), bbong (01-10-24), gcmak (05-05-23), wthrman2 (04-11-23)
Old 04-10-23, 10:25 AM
rdsterdave
rdsterdave's Avatar
Do you know if the spare wheel will clear these calipers?
Bechtold (04-10-23)
Old 04-10-23, 11:11 AM
89is500
9th Gear
89is500's Avatar
It does
Old 04-10-23, 11:14 AM
350phi
350phi's Avatar
47750-0W030
47730-0W030
yep, those are the two part number for the front left/ and right calipers.
then you need to add the pin kit: PN: 04947-0W010 must buy TWO. one for each caliper. this is the big bolt in the middle. You can also add the oem shims too if you want: PN: 04945-0W010 must buy TWO.
Add any front brake pads you like from 08-14 Lexus ISF. I personally use stoptech Street pads, you can find them on ebay. or any pads on rockauto. 100% bolt on. cool mod that should have been stock
@89is500 nice video!
The following 2 users liked this post by 350phi:
bbong (01-10-24), FLXYLXY (11-29-23)
Old 04-10-23, 11:50 AM
Grecian5
Grecian5's Avatar
This is helpful info, thanks @89is500 and @350phi ! How is the pedal feel and stopping power compared to the stock 4 pot Advics? I would imagine the power is better with more surface area, but would be worried that pedal feel would suffer trying to displace more fluid with the same master cylinder. Curious to hear your impressions.
Old 04-10-23, 12:21 PM
mleroux
mleroux's Avatar
47750-0W030
47730-0W030
Are you only running the ISF calipers and stock IS500 rear calipers?
Old 04-10-23, 12:24 PM
Vendetta
Vendetta's Avatar
Thanks for all the great info! I too am curious about the pedal feel as well as the performance. Is there there more bite and less fade?
Quick Reply: IS-F Front Calipers
