Gs 350 luxury trim
Old 08-02-23, 07:19 PM
joeflores1
joeflores1's Avatar
Default Gs 350 luxury trim
The 2016 gs 350 luxury trim doesnt have the fsport sway bar right,just the fsport trim.
if i want a better
Ride on turns i need to replace it right
Old 08-02-23, 08:13 PM
peteharvey
peteharvey's Avatar
if i want a better
The 2016 GS350 uses the same roll bars across the range.
Only the AWD uses a different front roll bar to get around the front transaxle.
If you're looking for the best ride comfort, the 2016-18 Luxury trim has the best ride comfort across the 8-model years.
Old 08-03-23, 06:21 PM
Mangsailor
Mangsailor's Avatar
With lux trim you also get AVS. While I have not driven a Lux and Fsport back to back in S+ mode, but I have driven both and hard.
I would say the Fsport is maybe a bit firmer in regular driving mode. So, it's really a question of what do you want? A luxury car with a sporty mode, or a sporty car with a super sport mode? The AVS will act as if the springs are stiffer, but in-fact will not be. There is a video of the 4th Gen GS premier that had explained how quickly adjustments are made by the AVS system between LUX and Fsport, and the Fsport was much more active.
I like my LUX, because I get a good mix between both worlds. However I'm sure a newer model than my '14 would handle better, but I'm very satisfied with mine... except I wish the springs were a bit softer.
I'd go through getting softer springs for the ride, but IDK how much AVS would like that. So that project is indefinitely tabled.
/Rant
Old 07-25-24, 06:47 AM
joeflores1
joeflores1's Avatar
Thanks guys
Mangsailor (07-26-24)
Old 07-25-24, 02:14 PM
jgscott
jgscott's Avatar
Received 1,390 Likes on 1,099 Posts
The Steering ECU is different in the F Sport vs Lux, I think also?
levv
04-19-22 06:01 AM
rorror45
04-02-22 10:40 PM
bigchromee
Build Threads
03-19-22 02:27 PM
symple84
08-06-14 10:03 AM
Quick Reply: Gs 350 luxury trim
