AFS OFF light flashing on after 20 minutes of driving.
07 RX350. I just replaced my AFS Height sensor near my rear passenger wheel. Thought everything was good but it seems like the AFS Light just turns on again about 20 minutes into my commute. Prior to the AFS OFF light flashing, it seems like the AFS functionality works fine and i can verify that the light swivels left and right when i turn. I also did the initialization procedure where i turn the steering wheel all the way to the left and right and press the afs button.
Is there something else I need to do here? It's driving me nuts!
update: I'm really confused still.... on my commute home the AFS OFF light never blinks and my AFS Functionality works fine. this morning it didnt come on at all. it's really annoying if anything.
I finally got a code on my code reader history that says the right motor is was faulted. It seems to function fine when the AFS OFF light isn't flashing though. is there a way to replace the AFS motor without opening up the entire headlight? My headlights are in pristine condition and I would prefer not to touch them. i'll live with the annoying flashing light if that's the case.
I found a thread on a 2nd gen GS for replacing just the motor. https://www.clublexus.com/forums/ls-...04-2006-a.html
