Brake torque spec please?
Hi everyone,
I have been reading the forum for quite sometime, finally here is my first post.
I am about to do brake job on my NX 450h+
Could someone please advise the bolt torque spec of front/rear brake caliper/ sliding pin and rotor bolt please?
Thank you very much.
Are you planning to change the brakes yourself?
I hope you know what you are doing, because you will need a OBDII device that can disable some stuff in order to work on brakes. Anyway, here is what I found for ya
-> https://autospecz.com/lexus/cars/202...pecs_brake.php
![EEK!](https://www.clublexus.com/forums/images/smilies/eek.gif)
![Big Thumb Up](https://www.clublexus.com/forums/images/smilies/biggthumpup.gif)
mikekwok (04-08-24)
mikekwok (04-08-24)
My 2015 300h never needed brakes the entire time I owned it. I just recently traded it in on the 24 450h+ it had over 125K miles on it. You just never hardly ever need brakes on a Toyota/Lexus Hybrid as they have regenerative braking and the friction brakes are only used between 7-0 mph.
My first inclination was to ask why OP needs to do the brakes, but I understand it's none of my businesses.
I suspect it's for a custom brake job, but would be nice to hear the actual reason.
True.. That would be me, I am a hypermiler trying to maximize my battery range and mpg. But many over at Prius Chat claim to have over 175K miles on the original brake pads.
Been there, done that. Just remember not to neglect caliper inspection/service. Both my hybrids needed regular maintenance on the calipers to keep them in top working order, especially with age. Its easy to get used to the regen always being there for easy driving, but due to lack of use if ignored the calipers get cranky and your full brakes might not be there when you need them. My Camry Hybrid never needed brakes, but the rear calipers did seize. My RX hybrid needed a couple set of brakes over 265,000 km but the calipers in it too did require extra TLC in between to keep them free and functional.
Hi mikekwok,
Please take photos and post about the process, so we can see what's involved. I'll be interested in tackling this if it's not too complicated. Thanks!
if you should ever need a replacement, the answer is used.
I got totalled from a red light runner a few years ago. Hitter was at fault thanks to my dash cam. A passenger in the hitters car filed a suit. Her attorney wanted to know everything about the mechanical condition/service records of my car. They tried every angle to find fault on my end.
These cars have electronic parking brakes and a special procedure needs to be done I believe in order to do a brake rotor / pads replacement. Do your homework first.
To be honest, I've been driving for over 40 years and use to do my brake jobs myself in the driveway. Not anymore, too much hassle for me, too dirty, have to deal with getting rid of old parts, things stick and seize, fingers smashed, back sore ... I can go on. I may come across as a PITA to the mechanic I entrust to do my brakes when I get them done, but a good and thorough brake job should leave you in a position with a good 40k plus miles of decent brakes. I have a hybrid approaching 40,000 kms and it's going to get a service 3 this week and have the brakes removed and inspected. I'm curious to see the comments on their condition, I'm a hard braker and know I'm not gentle on them, so it will be interesting to find out the condition of them.
Here you go! Here's how to prepare your rear parking brake into service mode in order to service your rear brakes.
marcel488 (06-27-24)
brake job on a new/mewer hybrid? a normally driven hybrid [any make] should not need a brake job other than periodic fluid exchange. I am expecting I will never need any brake pads/parts replacement for next 150k miles when I will replace with a new vehicle.
I know that may be a little optimistic sightdev, but I'm sure it's possible. I myself can see very easily thru my alloys that my rotors and obviously the pads too, are being used on my '22 NX350h and so at some point they will need replacement. Plus as Droid13 states in post #8 from his experiences the calipers should be serviced with some regularity in order to keep your brakes working at top form.
Here in Atlantic Canada they need to be done every year or two. They rust then seize. I do them myself every spring. The salt and humidity wreaks havoc on them. I realize my experience is different than the warmer climates.
I just had my first winter with a hybrid, and found it very difficult to prevent rust on the rotors. I got in the habit of doing a very hard brake at the bottom of our hill to clean them up.
bigchicken
LX - 3rd Gen (2008-2021)
12-08-19 03:37 PM
