Front Grill Camera
Front Grill Camera
I have a 2024 NX 350h premium, and I saw that I have the plug for the front grill camera.
Is there an option to fit the front grill camera to the current grill?
I found this exploded (section 1)view and was wondering if I get the front assembly and cover, will it work with the 14" infotainment system
I can't say for certain, but I suspect its not as easy as just plugging in a new camera. The 360 camera view system not only integrates front, side, and rear cameras (and the inside button) but also requires the software to be enabled to accept input from the cameras (combined with sensor readings from the parking and radar sensors) to be able to build (stitch together) the 360 view along with all the visual markups that are overlayed on the camera images. I'm going to be pessimistic that simply plugging in 1 front camera would suddenly bring just this one part of the full feature set to life no questions asked. Enabling the software feature is probably going to be the challenge for this and my gut says Lexus isn't going to make this easy.
hintonwood (05-15-24)
It is interesting that you have an unused connector on the front bumper below the lexus emblem.
Typically if the car wasn't optioned with the panoramic camera the wires would not be there.
power ?
Sometimes it is more effective for the car vendor, Lexus in this case, to pre-install a complete wiring harness instead of try to make separate partial wiring harnesses. Check to see if you have power on the harness and whether or not it is switched power. You can install camera if you have power. However, if switched power, then hard to set up as a security /theft camera
YMMV,
MidCow3
YMMV,
MidCow3
The following 4 users liked this post by tundotcom:
I searched in few sites, including salvage sites and cloud not find anything.
Hack, when I was at the dealership for service, not even one NX had the camera on it
I also saw this but there is no camera. Not sure if it's necessary.
https://www.ebay.com/itm/295815806224
