Check or replace this fuse (refer to attached diagram).
Is the interior switch and controls illumination working when the tail light or headlight switch is turned on?
Power for the fog light relay is also protected by the tail light fuse.
Perform this test to help isolate the cause (refer to attached drawings):
NOTE: you do not need the key fob for this test.
Open the driver's door and rotate the headlight control to the position indicated by the blue arrow.
Check if any of these lights are On . . . . .
- Amber front marker lights (location indicated by green circle)
- Parking lights (indicated by green arrow)
- License plate illumination (red arrows)
- Driver's door mirror switch and window switch illumination ***
*** May be hard to see in daylight. Rotate the headlight control between Off and the blue arrow position while looking at the white printing on the switches.
