ML Rear Speaker Rattle!
I know theres a lot of info on this Ive been reading a lot of posts and seeing YT videos--the ML rear speaker rattle. It just happened recently on my car, a rattle coming from the back speaker shelf, at all volume levels L and H, but cant pinpoint exactly where it is or how to fix it!
I watched 1 video the guy took out the back seat to access the rear shelf is that what I have to do?? If anyone is in So Cal area can help me fix this Ill pay cash!
![Sad](https://www.clublexus.com/forums/images/smilies/sad.gif)
Sounds like it is your subwoofer is shot and making the noise. You can look for one from a junkyard or you could go to autosound place to see if they could fit an aftermarket sub in the place.
Ken167 (06-29-24)
Believe the following kit below or something similar may resolve your issue, if it is with the OEM 8" ML subwoofer however, performing the repair by removing the rear seat / deck is the only to access the woofer.
Lexus 8" Subwoofer Speaker Foam Repair Kit FSK-8-1 (SINGLE)
https://www.simplyspeakers.com/toyot...xoCXkcQAvD_BwE
Per the following, perhaps it may be possible to perform the repair with just removing the rear deck;
ML IS350 sub replacement - coldone reply #7
https://www.clublexus.com/forums/is-...placement.html
Ken167 (06-29-24)
Located the following solution if interested in exchanging the OEM 8" subwoofer for aftermarket enclosure kit manufactured by NVX specifically designed for the 2006 - 2013 IS250 / IS350 / IS F vehicles. I assume subwoofer is compatible with both the OEM Non-ML and ML amps;
2006-2013 Lexus IS250/IS350/ISF - 10" Sub Enclosure | NVX BE-LEX-IS0613-VCW104 at Sonic Electronix;
https://www.sonicelectronix.com/item...VehicleSection
NVX B.O.O.S.T enclosure installation guide;
https://assets.sonicelectronix.com/i...ual_111814.pdf
NVX B.O.O.S.T. Subwoofer Enclosure - How To Install - Lexus IS 250, IS 350, IS F Video;
Subwoofer Features;
B.O.O.S.T. System Custom designed bass enclosure Compatible with select 2006-2013 vehicles from Lexus
-Hand-laid fiberglass shell
-Installs quickly and easily into the storage cubby on the left side of the trunk
-10" Dual 4 Ohm VC Series Subwoofer
-Power Handling:
-RMS Power: 800 watts
-Impedance: Dual 4 ohms
-Pressed paper cone with woven fiber top
-Custom High Roll foam surround with Nylon stitching
-Custom high roll foam surround with nylon stitching
-2.5" high temperature aluminum voice coil
-127oz. triple stacked ferite magnet motor structure with protective rubber boot
-Frequency response: 20-220 Hz
-Sensitivity: 83dB
-Complete amplified bass system package available here
-Authorized Internet Dealer
-1-year Manufacturer's Warranty
*Warning: Does Not Work with Convertible Models
Subwoofer Specifications
-Subwoofer Design Round / Circle
-Voice Coil(s) Dual
-Impedance (Per Voice Coil) 4 ohms
-RMS Power Handling 750 watts
-Total RMS Power Handling 750 watts
-Woofer Surround Rubber
-Woofer Composition Paper
-Sensitivity 83 dB
-Frequency Response 20 - 220 Hz
-Subwoofer Size 10"
Subwoofer Features;
-Power Handling:
-Sensitivity: 83dB
-Voice Coil(s) Dual
-Sensitivity 83 dB
-Subwoofer Size 10"
Ken167 (07-01-24)
