Anyone change their belt tensioner?
Old 06-23-24, 10:48 AM
DshngDaryl
DshngDaryl's Avatar
Default Anyone change their belt tensioner?
I had a friend ask me how to change the tensioner on their SC430. They are having problems getting the tensioner out
Anyone ever do it before?
This is a message they sent me:
I'm changing the tensioner and idler pulley, but I didn't realize how much work this was gonna be. If I'm not mistaken the only thing holding the old tensioner assembly in now is either the alternator or the power steering pump pulley.
i tried to rent a pulley removal tool and the one they gave me doesn't clamp on to my car.
I've taken off the belt, the timing chain cover both parts, and part of the whatever bolts are holding the alternator in place.
all the bolts holding the old tensioner in place are off, but to slide the old one off and replace it with the new one... something has to slide off in order to switch the pieces.
can you please tell me how the heck to finish his job.
I've watched videos on here on how the power steering pump pulley comes off so easily.
The pulley remover don't even grasp where they are supposed to on the pulley....
Old 06-23-24, 11:35 AM
DshngDaryl
DshngDaryl's Avatar
It looks like this guy has strong opinions on the subject
syphered (06-23-24)
Old 06-23-24, 11:39 AM
DshngDaryl
DshngDaryl's Avatar
doing some research for my friend, I found this "How to video" for a Sequoia, which I think has the same engine as the SC
Old 06-23-24, 11:40 AM
Bgw70
Bgw70's Avatar
Not sure if any of these pics will help…some pics from him would be helpful.
Old 06-23-24, 04:29 PM
syphered
syphered's Avatar
thank you so much you are a life saver i just gotta loosen the power steering pump, and the alternator, then she slide right off.
Old 06-23-24, 05:13 PM
syphered
syphered's Avatar
testing quote reply...
Old 06-23-24, 05:15 PM
syphered
syphered's Avatar
https://youtu.be/Whx1vIczvw8
besides the sleeping with everyone's wives part, Im with this man 100%
Old 07-02-24, 07:30 AM
syphered
syphered's Avatar
so i broke this connector and went to the dealer and they were no help in trying to find the part... anybody got any ideas what its called or the part #?
its the part that connects to the block or intake the female end..
Old 07-02-24, 09:12 AM
dan25man
dan25man's Avatar
That's the temperature sender/sensor (More Information for AISIN THSAZ8001 (rockauto.com))
What do you mean you broke the connector? it looks fine to me. If you mean you "broke" the tab, I wouldn't worry about it. Just zip tie it, and/or the rubber will hold the connector in.
Old 07-02-24, 09:15 AM
dan25man
dan25man's Avatar
Also, I've just removed the power steering pump pully from the pump with an impact in the past. To avoid having to remove the belt tensioner. Really that should be replaced at/with the timing belt/water pump. I've also had a non-OEM serpentine belt squeak so now I only get OEM. For the longest time I thought it was the idler pully making the noise, but nope, the aftermarket belt was just rubbing somewhere.
Old 07-02-24, 02:29 PM
syphered
syphered's Avatar
the inner plugs where the two prongs connect broke.it took me 2 weeks to do this job and im still not done cause of the broken sensor and I lost one of the bots that holds the power steering pump to the block. so i went to the dealership and ordered that i showed them the same pics i showed you guys and they were like we dont know what that is, btw they work for the parts dept.... well see if tomorrow they ordered the right bolt or not....
Old 07-02-24, 02:31 PM
syphered
syphered's Avatar
the rubber is all worn out on the inside and so im gonnna have to change that sensor, i really wish i could just give them the name and part number cause without it they are totally useless there...
Old 07-03-24, 12:11 PM
DshngDaryl
DshngDaryl's Avatar
Did you see this post by Dan the Man? Click on the link in Blue and you can probably get the part number from the rockauto listing. Or just order the part from Rockauto
syphered (07-12-24)
Old 07-12-24, 06:14 PM
syphered
syphered's Avatar
so I buttoned everything back up today and I couldn't get the new belt around the all the pulleys, every time I would get close the new belt tensioner would clicks and lets go of the tension I mean I'm about 1/4- 1/2 inch off, is there any way to stretch the belt or any tricks to getting this belt back on....
Old 07-14-24, 06:37 AM
dan25man
dan25man's Avatar
Uhh belts don't stretch by design. You need to fully compress the belt tensioner. I usually use a 24-16 inch breaker bar and you have to get the exact right position to have enough throw to fully compress it. Fun trick if you are using a 6-point socket and can't get that "right" position, you can take the 6-point of, rotate it 1/4 turn on your breaker bar end, and try again. Rotating it 1/4 turn (90 deg) set it up to act like a 12-point socket. So now you should be able to get the "right" position on the tensioner.
The following 2 users liked this post by dan25man:
doobs (07-14-24), syphered (07-14-24)
Quick Reply: Anyone change their belt tensioner?
