Gs300 2007 popping and very bad vibrating at idle
![Question](https://www.clublexus.com/forums/images/icons/icon5.gif)
i recently unbolted my rear mufflers and the car started popping so i reattached the muffler and it still doesnt drive right and idles very weirdly around 650rpm
i cleaned my MAF and check oil i dont know what else to do i dissconected the batter and reattched it and its still doing it and throwing me a check VSC and engine light what can i do to fix it
it also has a hard time accelorating as it hesitates going up rpm
did you pull the error codes?
2007 GS 300, you aren't in the US...correct? The 2007 GS was a GS350. Different animal. Find someone who can scan your codes.
i live in australia and its a gs300 to confirm i have the codes but dont know how to fix... here are the 4 codes i got
- cyl 4 misfire
- air intake sensor 1 circuit high
- mass or volume air flow a circuit low
- random/multiple cyl misfire detected
someone know any fixes or parts to replace?
thanks
- cyl 4 misfire
thanks
- cyl 4 misfire
thanks
- cyl 4 misfire
thanks
rvaddict
Performance & Maintenance
12-14-20 04:10 PM
