Locatioin of 09 GS350 evaporator drain hose
8th Gear
Hello everyone I can't find a good source online showing where the evaporator drain hose is can anyone give me good directions or show me an image where the evaporator drain hose is located. Thank you
There should be videos on youtube and here you just got to search for them. The location of the plug or plug if im not mistaken is just over the transmission bell housing. There were threads showing what plies needed to remove the plug.
But for an 09, I dont think you should have drain issues, as this was common on the early models. Are you having smell in the cabin? If so maybe your evaporator is dirty, they make special sprays that can help clean them aswell as the air cleaner housing
8th Gear
Yes, my cabin is smelling. I have the cleaner used to purge the smell and mold in your evaporator. I just need to locate it.
Is this video very similar to where you'll find the plug for the 09 GS350?
Heres a video, probably better for you to use a cleaner. I had a similiar issue and I wanted to do the drain but when I read that the 08-up do not have a drain issue I didnt bother with it. What I did was sprayed the evaporator with a bunch of chemical cleaners to basically flush the dirt out.
Maybe experiment with cleaners such as this brand
8th Gear
I did this but with ozium spray and sprayed the plenum with air cycle on fresh, but I forgot to take the filter out lol. When I turn AC off it gets a bit musty which is why I'm gonna clean from the evaporator hose area
LinkLichen (06-26-24)
8th Gear
Looks good but I don't know how it differ to any other cleaner. gonna use that Kool it soon since I bought it some time back anyways. If you do ever try it let me know.
