Hi, on my 2007 lexus LS460 I have the "park assist" switch that doesn't light up, so it stays off.
So no front or rear detection, but the rear camera works. No warning message or light on the dashboard. Any ideas?
When did it stop working? Any dead battery or work done on car? Did you check the fuse? Any codes from OBD2scan?
I am the new owner I bought it just like that, no idea when it does not work.I also thought about the fuse, but which fuse is it?The diagnostic kit shows no fault. I would need techstream to investigate further.
Pry the cover off the 4 switch panel and see if the switch is unplugged then watch this video for the location of the fuse for parking assist or check the fuse first then check the switch connection...your choice.
