24LC 2800 miles
Old 06-30-24, 09:27 AM
Barncobob
Barncobob's Avatar
Default 24LC 2800 miles
excellent car so far...I just recently experimented w ith "M". Was always scared to in other cars because of leaving tranny on the hwy..OMG is it a blast...just like driving a stick...upshift/downshift whenever and the exhaust is perfect. :}
2959 (07-01-24)
Old 06-30-24, 11:05 AM
tecman
tecman's Avatar
I do wish we could change gears from the shift lever. It can be awkward when turning the steering wheel and I'm not really a both hands on the wheel driver.
Old 06-30-24, 11:27 AM
np20412
np20412's Avatar
This is one thing I noted and disliked heavily during my test drive. In my GS I can use the paddles and the shifter and it's my ideal driving position to rest one hand on the shift for up shifts and hold the steering wheel with my left hand for downshifts. Sure it's not traditional but after years of driving stick my right hand just defaults to the shifter at all times lol, I'm just not used to two hands on the wheel at all during casual driving.
It's not enough for me to disregard the car, but it was definitely something I noticed and stuck in my mind.
Old 07-01-24, 05:01 AM
2959's Avatar
Agree, also played with it recently. Was only "sketchy" about returning to D mode (having to move the shift left to N then D when moving). Unless someone knows another way to return from M to D without going to N first?
Old 07-01-24, 05:08 AM
np20412
np20412's Avatar
Yes jsut pull the shifter down as you did to get it into M in the first place. That returns it to D
Old 07-01-24, 05:10 AM
2959's Avatar
While moving or do you need to press the brake pedal first (looked in the manual and didn't see anything)?
Old 07-01-24, 05:19 AM
np20412
np20412's Avatar
You don't need to do anything you can do it on the fly under full acceleration if you wanted to
Old 07-01-24, 05:44 AM
2959's Avatar
Thanks! Something to play will today.
Old 07-01-24, 06:16 AM
kirkd1
kirkd1's Avatar
Just hold the + up shift lever back for three seconds to return to D.
Old 07-01-24, 06:52 AM
2959's Avatar
Knew about that when in D and paddle shifting, did not see where that worked when in M.
Old 07-01-24, 07:19 AM
np20412
np20412's Avatar
Won't work in M, that's only to return to D when you've used the paddle while still in D.
2959 (07-01-24)
Old 07-01-24, 12:14 PM
2959's Avatar
Ok, I tried numerous ways after selection of M to get back to D. Once in M, tried pulling it back again several times, holding it back, going fast/slow etc. does nothing and stays in M. Once M is selected, the only way it returns to D is by moving to N then D. Am I missing something?
Old 07-01-24, 12:25 PM
np20412
np20412's Avatar
I could have sworn that's how I did it in the 24 I test drove, but maybe I did move left then down. Whatever way I did it, the car definitely did not actually shift to N before moving back into gear when it hit D. It just stayed in gear or shifted to the appropriate gear when I did it while acceleration. If you do it fast enough left then down all in one swift fluid motion I think the car won't have time to actually shift to N anyway.
Old 07-01-24, 12:35 PM
2959's Avatar
For me, left than D was no hesitation from M if done smoothly. The transfer was seamless (although once I just moved it to N and it did go into neutral with buzzers since I was moving).
It's just seems strange, my other Lexus's for M is while in D, move left than up/down for shifting. Move it back right to return to D.
Old 07-01-24, 12:51 PM
np20412
np20412's Avatar
Yup that's how my GS is, separate slot altogether for M and allows for shifter use to change gears. Sad to miss that feature on LC but I'm sure I'll adjust!
Quick Reply: 24LC 2800 miles
