2008 JDM Import IS-F won't start
4th Gear
Hey all, have run into an issue with my IS-F this morning, which is essentially the same as the video below.
I changed my taillights out for a set of VLAND lights last night, and mistakenly tried testing them out while the engine wasn't running and built a lot of pressure up in the brake lines to the point the brake is incredibly stiff to push.
My brake lights work fine (this is no longer the case 12 hours later - also getting a VSC System Check Error), however the car does not recognise that I'm pushing on the brake to start the car.
Has anyone experienced anything similar? I have tried pushing down hard on the brake to start the car, tried jumping the car, disconnecting the battery, putting the old taillights in to no avail.
Is this a brake switch or pressure sensor? What part number would I be looking at?
Tech Info Resource
![](https://www.clublexus.com/forums/images/ranks/rank-smod2.gif)
Does the ignition ever go green? No green, no start. Ever.
CooperD (Yesterday)
4th Gear
It hasn't gone green at all today. No issues starting it prior to installing the taillights and testing them (without the car being on) yesterday.
It sounds like something isn't wired up properly or possibly a fuse, tail lights and brake pedal are linked. I would swap the taillights back to oem to see if the car at least starts.
whats involved with the installation of the vlands? any repinning? I kinda doubt the JDM ISF's wiring harnesses are the exact same as a US spec
Try this if you want, push the start button once without stepping on the brake and give it a few minutes then still without stepping on the brake push and hold the start button for about 15-30 seconds and see what happens.
4th Gear
4th Gear
I am now getting a VSC warning on the dash, as well as the “press brake to start engine” warning. Battery appears to be a bit low on charge, trickle charging didn’t seem to do much. Hoping it’s just a battery, but seems like it could be more.
NickDangr
07-25-23 08:54 AM
devyvalent
05-31-18 06:18 AM
newgsman
IS F (2008-2014)
50
04-23-17 12:06 PM
