What could be the cause for these error code?
Old Yesterday, 08:57 PM
johnjohn876
johnjohn876's Avatar
Default What could be the cause for these error code?
Ileft my 2006 Lexus GS300 for 10 days, to come back with it dead. After jumpstarting it and scanning it with my FIXD OBD scanner I got these codes. I know that the p0136 is because of a bad o2 sensor, but what about the other ones? For the C1223 Lamp Brake error I checked and all my brake lights work perfectly. And for the low batter you can see in the second picture mine has 13.3 volts. Thanks in advance.
Old Yesterday, 10:32 PM
skur
skur's Avatar
When car batteries die they're known to throw a ton of false codes in other electronics. I'd clear the codes and see which come back
Old Yesterday, 11:45 PM
ibidu1
ibidu1's Avatar
Sounds like a bad battery, like skur suggested once you get a low voltage it does funky things to the cars modules and ecu's. Having a weak battery can destroy your starter and alternator. For me I like to replace mine early
ljdsong
IS F (2008-2014)
21
04-23-24 04:27 PM
SENSAY813
04-17-24 01:22 AM
Dkpgh
ES - 5th Gen (2007-2012)
02-08-20 04:01 PM
bryceis250
12-31-19 07:05 PM
richieschm
04-08-14 04:58 PM
Quick Reply: What could be the cause for these error code?
