Where should I tap in to wire a kill switch? The only thing I want is for the car to not start unless the switch says otherwise.
The Easiest is to wire it, to Disable the Ignition System, and also so it Can't be Hot Wired either!
You're going to have to do some research to find the Best place for that,
or buy a decent Remote Vehicle Disabler, and then it Can't be Started, until You give it the Command!!
