2009 Lx570 shakes with acceleration below 40
Hello Friends, I have a problem with my 2009 lexus lx570 There is a vibration in the car, which is evident when accelerating to 40, And This problem appears when i used the car for half an hour or more, but when the car is cold, this problem does not appear during use!! And you feel this shakes in driver seat more than the others seats, What could it be?
If it is a high frequency vibration it could be a front wheel bearing. It could also be a bad or dry front ujoint. Grease the ujoints and see if that helps. If it is a wheel bearing, much more involved and probably a job for your mechanic.
Thank for your replay, actually I have checked all what you said above and everything working perfectly and there are no problems with them at all. The problem what i have is somewhat little bet strange!!, as the vibration does not appear until after driving the car for a while, and the vibration appears between speed 0 to 40 , and when I press the gas pedal, or when accelerating during this speed, and its disappears after that, or when I lift my foot from the gas pedal, or when the car is cold!!!
Bozookah
03-08-10 01:42 AM
waijai
North Texas Lexus Club
21
09-21-09 09:56 AM
CompuMan
ES - 5th Gen (2007-2012)
09-20-09 06:51 AM
