Lexus es 300 2019 - Lateral movement at speed > 160 km/h
I want to ask you if you have felt a fine lateral movement that resembles the beat of the cant only at speeds higher than 160 km/h. I mention that I turned off all line sensors and other road alarms
- Beat of the Cant: When you say "beat of the cant," do you mean a rhythmic sensation or vibration, kind of like the side-to-side movement of a train on a tilted track? I understand "cant" as the banking of a road, so are you feeling something related to that at high speeds?
- Lateral Movement: Could you describe the movement in more detail? Is it shaking, swaying, vibrating, or something else? Does it change depending on the road or conditions? Which part of the car feels it most?
- Speed: You mentioned this only happens above 160km/h. Does it start suddenly at that speed, or gradually as you get faster?
- Anything Else: Are there any other sounds or unusual feelings that go along with this movement?
- Recent Work on Your Car: Have you had any work done on your Lexus recently, like tire rotations or suspension adjustments, that might be related?
MCV20
211
09-18-12 05:22 PM
