2017 LexusGS350 F Sport - Push Gas Door Stuck Closed
Old 07-24-24, 08:27 AM
JustLofi
3rd Gear
JustLofi's Avatar
Default 2017 LexusGS350 F Sport - Push Gas Door Stuck Closed
Hi all,
My SIL's 2017 Lexus GS350 F Sport push gas door is stuck closed with all doors unlocked. Pushing around different spots of the gas door did not work, and it acted as if it was still locked (There was no usual ease of pushing in the cap). Both the vehicle trunk release from inside the cabin and the key fob do not work. They have been accessing the gas door through the emergency release in the trunk, but would like to have it fixed (Preferably DIY). I tried looking online for solutions to the issue and through this forum but have found nothing. Just wondering if anyone has been experiencing this problem and had it fixed on their own or could help provide insight on this. Thank you kindly.
GS350 Push Gas Door (Opened after using emergency release located in trunk)
Old 07-24-24, 08:43 AM
bclexus
bclexus's Avatar
Received 2,227 Likes on 1,591 Posts
Sounds like you need a Fuel Door Spring
I hope it helps you!
Old 07-24-24, 08:56 AM
JustLofi
3rd Gear
JustLofi's Avatar
https://youtu.be/gryr0U-zVGQ?t=39
Thanks for your reply. I actually stumbled across this video. Sadly the part is not compatible with the 4th gen GS350 (2013-2020).
Old 07-24-24, 11:04 AM
tammap
tammap's Avatar
Here you go.
bclexus
bclexus's Avatar
It looks like for the Lexus 4 GS the entire fuel door assembly is needed. But because the fuel door is permanently glued or epoxied to the fuel filler assembly - that would require that the door would need to be painted to match the vehicle's exterior body color.
I suspect the original fuel filler assembly can be removed and the spring mechanism you see in the images below can easily be fixed. My guess is that the spring came out of the hole (red arrow) you see in the image directly below - probably from someone excessively opening the fuel door too far.
Probably the spring just needs to be loaded and reinserted into the hole. Nevertheless, once the fuel filler assembly is removed it should readily be apparent what the problem is pertaining to the spring, and it should be easy to fix...
You'll notice in the second image there are two Phillips head screws - one that actually holds the spring and the other that can be removed to access the spring hinge area.
My fuel filler assembly door hinge:
Old 07-24-24, 11:06 AM
bclexus
bclexus's Avatar
Originally Posted by tammap
Here you go.
That's the locking plunger release actuator mechanism.
Old 07-24-24, 11:09 AM
tammap
tammap's Avatar
(See page ) [ DOOR / HATCH: LUGGAGE DOOR HINGE TORSION BAR: REMOVAL ] [ DOOR / HATCH: LUGGAGE DOOR HINGE TORSION BAR: REMOVAL ] [ DOOR / HATCH: LUGGAGE DOOR HINGE TORSION BAR: REMOVAL ]
  1. REMOVE LUGGAGE COMPARTMENT TRIM INNER COVER LH
[ DOOR / HATCH: TRUNK LID ACTUATOR: REMOVAL+ ]
  1. REMOVE LUGGAGE CLOSER MOTOR ASSEMBLY (w/ Power Trunk Lid System)
  1. REMOVE FUEL LID WITH LOCK MOTOR ASSEMBLY
    1. Loosen the temporary bolt.
    2. Remove the nut and disconnect the parking brake ECU from the vehicle body.
    3. Disconnect the connector.
    4. Detach the clamp.
    5. Detach the claw and remove the fuel lid with lock motor assembly.Text in Illustration
      *A w/ Power Trunk Lid System - *B w/o Power Trunk Lid System - *1 Temporary Bolt
Old 07-24-24, 11:11 AM
tammap
tammap's Avatar
Remove the actuator
Old 07-24-24, 11:16 AM
tammap
tammap's Avatar
  1. INSPECT FUEL LID WITH LOCK MOTOR ASSEMBLY
    1. Check the operation of the fuel lid with lock motor assembly.
OK:
  1. Apply battery voltage to the fuel lid with lock motor assembly connector, and check that the fuel lid with lock motor assembly operates smoothly as follows.
Measurement Condition Specified Condition Battery positive (+) → Terminal 1
Battery negative (-) → Terminal 2 Unlock Battery positive (+) → Terminal 2
Battery negative (-) → Terminal 1 Lock
  1. If the result is not as specified, replace the fuel lid with lock motor assembly.
Old 07-24-24, 11:35 AM
JustLofi
3rd Gear
JustLofi's Avatar
Thanks for the informative posts everyone. It's the best advice I've found online, no kidding. I'll check out the spring mechanism first and go from there. I'll come back with updates when I am able to have this resolved. Thanks again everyone, it is very much appreciated!
bclexus (07-24-24)
QLex300
04-11-23 03:52 AM
BrooksLC
07-30-14 12:45 AM
Sup2jzgte
06-06-08 10:05 AM
Rockero28
11-05-07 03:14 PM
THE_CEO
02-04-03 06:40 PM
Quick Reply: 2017 LexusGS350 F Sport - Push Gas Door Stuck Closed
