Hi everyone, i recently had a battery change and in doing so my power steering light has turned on and stopped working. Ive checked the module and fuses and found plugs and everything is wired in properly and not blown. Just trying to find out what to do as it scans and come up with these codes
C1515
C1525
We tried to recalibrate but at the end of it, it says communication failed and then we cant proceed.
Any tips please???
C1515
C1525
Any tips please???
Mine happened right after a battery change as well. In order to fix it, I removed the battery, lifted the Cover from underneath the battery which was covering up the power steering ECM. I unplugged both ends of it and took it out and made sure it was free of debris. And then used a little dielectric grease on both of the tabs and reinstalled it. It reprogrammed itself and I have not had a problem at all. Hope that helps.
