Headlight Low Beam
Headlight Low Beam
I just purchased a 2009 IS 250 and the driver side low beam does not work. I tried replacing the HID bulb, but that did nothing.
I read that it might be a fuse, so I checked the headlight low beam fuse in the engine fuse box. It looks fine. I even switched it with the fog light fuse that I know works, and still nothing.
Is there possible another fuse in a different box that I am not aware of that could be causing the low beam not to work? Also, I checked the ballast and it does not look bad.
sheetmetalfab (08-03-24)
Ballast
Bad ballast
Hardest part was heating up the seal so I could break it… I had to use a blow dryer because I didn’t have a heat gun.
sheetmetalfab (08-26-24)
Those are some serious green crusties. Eric O (South Main Auto YT) approves of their detection and repair =)
theblooray
05-06-22 09:51 AM
