Front passenger side creating a creaking noise.
10th Gear
I recently (in the past month) have noticed that my suspension feels a bit more sensitive than normal, it feels like i can feel every single bump on the road and im also hearing a creaking noise. I can recreate the noise when i press on the fender on the passenger side. I have some knowledge on fixing however i have not done much of any suspension work. Any thoughts?
Drive it up on blocks or ramps, verify sound can be duplicated once car is blocked. Have a helper push on nose while you listen and place you hand on suspect areas to feel the vibration. Likely suspects will be at any ball joint with a torn boot. If no tears, sway bar end links, followed by lower and upper ball joints. Worn links rarely make a car drive bad nor does loose lower ball joint as it has a giant spring pushing on it. A loose top BJ or tie rods, yes.
10th Gear
emperor651 (08-16-24)
Jaynight
LS - 5th Gen (2018-present)
05-24-24 03:30 PM
Meego
07-29-10 08:27 PM
