2004 Lexus gs300 losing oil
Old 08-14-24, 12:34 PM
MixedKoolaid
1st Gear
MixedKoolaid's Avatar
Default 2004 Lexus gs300 losing oil
Hello i have a 2004 lexus gs300 with about 130k on the new motor and transmission. And every 2 weeks or so i have to top off my oil with a quarter of a qt of oil if not more. From what i can see i have zero leaks and theres zero smoke coming out of the exhaust (i am currently an apprentice at a dealership and have lifts to inspect my vehicle) my coolant is also perfectly clear and my oil does not look burnt. So i keep wondering where the hell is all my oil going. It leaves no drips on the ground.
some background info cam seals have been replaced
Valve cover gaskets have been done
new pcv valve
crank seal has been replaced
vvti cam gear o ring and bolt seal has been replaced as well.
absolutely zero noticeable leaks with no drips. Also zero smoke.
i am wondering if this oil consumption is somehow normal or if it could be some other possible issue. If anyone could offer some info that would be great
Old 08-16-24, 01:37 AM
LiamLexusBuild2
2nd gear
LiamLexusBuild2's Avatar
Default Sounds like you have hemorrhage Of the valve seals
new pcv valve
Sounds like you have hemorrhage Of the valve seals and oil is pissing into your combustion chamber an out your exhaust… I just had a major oil hemorrhage of the cam seals an valve cover gaskets on my 1998 GS300 with 155k miles… I literally just replace valve cover gaskets, cam seals, front main seal, VVTi Gear Rebuild Seal, an did the timing belt, timing belt tensioner, water pump, intake manifold gasket and spark plugs while I was in there and it seems I have zero oil leaks on mine now maybe the oil pan but not much…. But those oil leaks pissed all over my driveway as would all other oil leakage the rear main the lower and upper oil pan gasket all would leak out so it has to be your valve seals bc I don’t see your piston rings leaking so bad to the point it’s coming out of your exhaust with out clatter…
do you notice any miss fire or if it’s running rough? The plugs if not fouled out will 100% foul out soon from oil and miss fire I would get the seals replaced before you have tons of carbon build up in your combustion chamber from burning that much oil…
Old 08-18-24, 06:18 PM
dwoods801
dwoods801's Avatar
Have you pulled the lower engine shield off?there is a big plastic shield that goes across the entire bottom of the engine compartment. And it will catch pretty much any fluid leaking from the engine.so you could have an oil leak and never see an oil spot in your driveway.
Old 08-20-24, 03:10 AM
ClaireLewis
1st Gear
ClaireLewis's Avatar
new pcv valve
Do you still need help?
Old 08-28-24, 07:58 PM
lastguy
lastguy's Avatar
Mine is 2005 also got oil leak, previously is every 5K mile It get to bottom of scale. My skill is limited yet able to change timing belt, I have no job now and not able to hire some body so seek help again here.
what I changed:
valve cover gasket,oil pan & gasket,Intake VVTi CAM gear o-ring,
BUT I have not changed CAM/Crank shaft seals, it is a bot hard for me?
Oil pump/upper oil pan:Need to hang up engine right? I am not able to do.
It seems I need to remove the engine front cover? I see in this thread people mentioned they changed these and that, anyway your guys can give video link on these change - might be on youtube yet I am not very sure the parts you replaced. any help would be appreciated, car is 150Kmile. I relaced lower control arms, timing/spark changed at 110K.
Another question, car speed up is quite slow now compared with say 80K, yet drive still smooth.
gsean400
02-16-23 01:52 PM
Toby22
12-25-21 04:32 PM
Allusuc
03-07-21 01:38 PM
Randallex
05-25-16 10:41 PM
Pogigreg
01-28-12 11:50 PM
Quick Reply: 2004 Lexus gs300 losing oil
