P0031 and P0051 Codes - Coincidence???
10th Gear
Today I had a new stereo and related accessories installed on my RX350 (2009 with 113K miles). About an hour after leaving the installation shop my dash popped up with the CEL, traction control and VSC warning lights. A scan revealed both P0031 (Bank 1, Sensor 1) and P0051 (Bank 2, Sensor 1) error codes indicating the "Heater Control Circuit Low." I reset the CEL's 3 times and within a mile or roughly 5 minutes of driving the lights will come back on with the same error codes. I understand the O2 sensors can fail and with my high mileage are likely overdue. I was surprised however that both banks would fail at the same time. Is it likely for both to fail at the same time? Could anything the stereo installer did have caused this to happen? From my online reading I am wondering if something happened to the ECM but I don't understand it well enough to know if that is something to explore. I appreciate any assistance. TIA, Todd
One code may be coincidence but two codes?
No way. Lol
If they put in a new stereo they may have pulled fuses or who knows what
Check out the other members post above first
Next, I'd go over their work with a fine toothed comb and check all the fuses and see if any are missing and if they did a power tap in the fuse box for the new deck and messed something up.
When in doubt, always check your work.
In this case, check the last guy's work. Lol
No way. Lol
MrBlueSky (Yesterday)
First off, these are not O2 sensors, they are A/F sensors, and are quite different. Looking at the wiring diagram, these 2 A/F sensors share the +B (12V plus, yellow wire) hot connection, then the yellow wire goes the the A/F relay. So I would suspect something with that relay, or the connections to it.
The grounds for the A/F relay are shared with the EFI relay, so if the car is running, they are likely ok. The hot to trigger the A/F relay violet wire, does indeed end up at a fuse as suggested above:
10th Gear
"Could very well be more battery voltage if they left the doors open for any extended period of time that is very common. Do you buy chance have a battery charger or maintainer you can use overnight?"
Thank you "Leeper" for the suggestion. Per your suggestion, I put the battery charger on and it immediately posted a battery full message. I set up maintainer mode and have it running now.
10th Gear
No way. Lol
No way. Lol
10th Gear
10th Gear
Thanks - I checked all three fuses and they appear to be fine. Is there any reason to swap them out anyway?
For anyone following along, I highly recommend the volt meter that plugs into the cigarette lighter.
They are sold online and at local auto parts stores
It's a simple device and shows your battery voltage at all times when the key is on.
Bonus plus, I got one that shows my volts plus two USB charging ports and I leave it plugged in to the cigarette lighter always.
Fast, easy, cheap, approx $10.
Worth it. 🤓
Worth it. 🤓
I would be tempted to measure voltage to ground on the yellow wire to the bank 2 A/F sensor, it is easy to get to, maybe check the ground (blue wire) while you're there.
10th Gear
A quick update - I left the battery on the charger/maintainer for about 7 hours and then spent the afternoon re-checking fuses and reviewing every wire connection. I replaced the wire nuts used on the black, red, yellow and blue wires. I also tidied up some of the routings used for various wires. I happened to have a volt meter that plugs into the cigarette lighter and as was suggested, I checked the voltage throughout the afternoon (it ranged from 12.2 sitting and 13.3 running). I have reinstalled the stereo and we drove the car for about 90 minutes this evening. So far, no codes or errors. I am cautiously optimistic that perhaps it was indeed a battery drain or wiring issue. I spoke with the installer who indicated they did not pull any fuses or disconnect the battery. He was very agreeable to look at everything which I will do if the codes return. I will update the thread should things change. Thank you to all for the great suggestions.
Margate330 (Yesterday)
