remove the glovebox on my 1998 will not come out stuck
Old Today, 01:23 PM
Ajar1998
4th Gear
Ajar1998's Avatar
Default remove the glovebox on my 1998 will not come out stuck
Hi all I am in process of repair my ecu, I cannot remove the glovebox. I watched a dozen videos and searched forums, I found 3 screws and 2 bolts but the box won't come out what am I missing?
It feels like it is attached at the top corners still. Are there plastic tabs still holding?
Car is 1998 with CD mint low miles I am trying to keep in best condition many thank you for help!
Old Today, 02:23 PM
Ajar1998
4th Gear
Ajar1998's Avatar
Plastic tabs! 1 corner became stuck feels like 1 more hidden bolt but no way it can exist?
Old Today, 03:18 PM
aptoslexus
aptoslexus's Avatar
Over on the far right side there's a cap screw. Not sure if you got that but then the right side should come loose. There's a metal clip there also but you just have to pull back.
Old Today, 03:48 PM
Ajar1998
4th Gear
Ajar1998's Avatar
Hi! I did get that bolt yes. it required quite heavy pulling more than I am comfortable with to remove glovebox. Thankfully did no break any plastic thank you for suggestion
Door key remote is mounted to ecu bracket, you must unbolt CD player to unbolt ecu.
ECU now on way to be fixed, thank you!
Old Today, 03:50 PM
Ajar1998
4th Gear
Ajar1998's Avatar
Bad electronics!
socaligs
GX - 2nd Gen (2010-2023)
08-12-24 04:35 PM
glennp00
ES - 6th Gen (2013-2018)
04-26-24 02:23 AM
2oa
ES - 7th Gen (2019-present)
09-16-23 01:49 PM
leakz
RC - 1st Gen (2015-present)
03-03-23 05:23 AM
JBeau
IS - 1st Gen (2001-2005)
05-02-20 02:07 PM
Quick Reply: remove the glovebox on my 1998 will not come out stuck
