Replace Scuff Lighting aka Door Sill Bulb Driver side
Old Yesterday, 06:29 PM
h42ka1
7th Gear
h42ka1's Avatar
Default Replace Scuff Lighting aka Door Sill Bulb Driver side
Hello There,
My 09 RX, the scuff light a.k.a. door sill bulb (driver side where Lexus is printed) not working. I get a warning sign at night. All other bulbs are working as expected. Can someone suggest, how to fix this.
Thanks in anticipation
Old Yesterday, 10:21 PM
MattRX
MattRX's Avatar
That scuff plate light won't give you a bulb out warning. Are you sure the rear sidemarkers and fronts are fully operational? You'll need to solder in a 3mm bulb after dissembling the scuff plate. It's a messy and annoying job, but doable if you don't mind messing with electronics. The 3mm bulb is soldered onto a small circuit board
tweety562
01-21-19 11:51 PM
GX460PREM
GX - 2nd Gen (2010-2023)
07-15-16 11:11 AM
panda327
03-07-15 06:14 PM
shikbas
05-23-07 11:53 AM
Quick Reply: Replace Scuff Lighting aka Door Sill Bulb Driver side
