My car has been beeping ever since I changed my gearbox
Old Yesterday, 02:19 PM
Alyssasibia
6th Gear
Alyssasibia's Avatar
Default My car has been beeping ever since I changed my gearbox
I have a Lexus RX 330 2004 which I recently changed the front gearbox and the suspension , since then, my car beeps whether i turn or I drive even in straight line beyond 40MPH. The beep comes along with a light in dash with an icon of the car with curves.
Old Yesterday, 02:46 PM
Mesquite77
Mesquite77's Avatar
Search for ABS sensors on the wheels.
Old Yesterday, 02:47 PM
Leeper
Leeper's Avatar
Your car only has one gearbox. What are the codes when yo plug in a OBDII reader? You can borrow one from most any large auto parts retailer for free. That warning light is likely your traction control but you'd need to verify you've provided no pics to confirm. You've replaced ALL the suspension? You post make little sense and lacks pretty much anything needed for a decent diagnosis.
Old Yesterday, 02:54 PM
Alyssasibia
6th Gear
I diagnosed it nothing no fault was shown, it used to show a symbol on the dashboard before but now it doesn’t show anymore and it’s still making the noise …
Old Yesterday, 02:55 PM
Alyssasibia
6th Gear
I checked all the sensors they’re all working fine
Old Yesterday, 02:58 PM
Alyssasibia
6th Gear
this is the light that blinks on the dash
Old Yesterday, 04:22 PM
Leeper
Leeper's Avatar
That is a traction control warning light, search this forum you'll find a number of threads and solutions how to fix it
Btw in your first pic the light on the left shows a "check engine" light on (if that is still there it needs to be addressed immediately could be something very important), on the right it is showing a "TPMS" (tire pressure management system) warning usually means a tire is low on air pressure but that could also affect your traction control
Old Today, 01:51 AM
Alyssasibia
6th Gear
yes thank you I’ve sort out the tire pressure the tire pressure is now ok but the sound is still beeping can someone help me with a video on how to get rid of the sound
Old Today, 02:30 AM
Nevada
Nevada's Avatar
How did you verify that the ABS sensors are working? No ABS system faults detected?
Have a look at the wheel speed sensor values on a diagnostic scan tool while driving, do they each show the same MPH? I suspect one or more wheel speed sensors are inoperative, probably caused by an open circuit.
Old Today, 02:33 AM
Alyssasibia
6th Gear
okay thank you so much I’ll look into that today and give a feedback
neilsarkar
RX - 5th Gen (2023-present)
45
07-19-24 10:06 PM
R9000
02-28-23 06:40 PM
Quick Reply: My car has been beeping ever since I changed my gearbox
