Noise reduction and sound deadening NVH
Anyone takes any extra steps with their NX to improve the noise levels and/or any ride harshness? Wonder what the NX could be missing that other Lexus models have and we could incorporate?
- Know Dynamat in the door panels and/or wheel wells is usually a popular first step
- Using an ODB dongle to disable the fake engine noise (Engine Sound Enhancement) that Lexus pumps in through the speakers helps a lot and is super cheap and reversible
- 18" tires instead of 20"
- Replace the stock run flat tires with regular tires
- Has anyone with the base/premium trims tried installing the front and rear performance dampers from the F-Sport / Luxury trim? Those are said to help with NVH, but wasn't sure if they're relatively plug-and-play or not to add to the lower trim?
- Using an ODB dongle to disable the fake engine noise that Lexus pumps in through the speakers helps a lot and is super cheap and reversible
- Has anyone with the base/premium trims tried installing the front and rear performance dampers from the F-Sport / Luxury trim? Those are said to help with NVH, but wasn't sure if they're relatively plug-and-play or not to add to the lower trims
![Lightbulb](https://www.clublexus.com/forums/images/icons/icon3.gif)
You might want to look at the previous discussions on NHV:
https://www.clublexus.com/forums/nx-...ound+deadening
Some of the ideas are pretty good for reducing NHV![Thumb Up](https://www.clublexus.com/forums/images/smilies/thumbsup.gif)
Also, while some like RFTs, they are noisier. But anyway, when you get to the tire replacement stage , there are tire much quieter than OEMs even if you want to stick with RFTs.
Also, if you have 20 inch tires and are willing to spend the money swapping out to 18 inch wheels and tires will be quieter.
YMMV,
MidCow3
YMMV,
MidCow3
Base, Premium , and Luxury have the same suspension. The F-Sport is different. The 450h+ rides different than 250,350, and 350h.
Also, you will see a difference in ride between 18" and 20" tires; 18" being smoother.
YMMV,
MidCow3
YMMV,
MidCow3
Here is a thread that discusses the fake noise and how to get rid of it ( lots of reading though, enjoy
) : https://www.clublexus.com/forums/nx-...ght=fake+noise
YMMV,
MidCow3
![Wink](https://www.clublexus.com/forums/images/smilies/wink.gif)
YMMV,
MidCow3
Carista but it was like $50 USD on Amazon (just used the free trial for the subscription service)
makbn (08-28-24)
Is this fake engine noise aka "Engine Sound Enhancement" produced in Sport mode only? Somehow I didn't notice it in NX 350h '25 in Normal mode and can't find it in manual.
It is my understanding that the "active noise control" is only on the NX350 and its more of a noise cancelling system rather than adding noise.
ANC does cancel noise - there’s a separate Engine Sound Enhancement that adds engine noise. 1st gen NX had a **** on dash to control it, but they removed that for the 2nd gen. Only way to remove is via ODB
YMMV,
MidCow3
I finally got around to playing with these settings. Started by turning off the "ESE" (aka the fake engine sounds) and went for a spin. To be honest, I heard absolutely no difference. Next I turned off the ANC and tried again (ESE still off). This time I was able to notice a slight difference, but very slight. The one thing that most stood out to me was I did a full throttle acceleration from stop, the engine did sound a bit more GGggRRRrrrrrr racy especially winding past 5000rpm @ full boost. However when I reached a tad too far over the speed limit I eased up substantially on the gas and heard a (for lack of a better term) wind down noise that I'd never heard before. I know on older cars with turbos when you back off the throttle quickly after coming off of full boost the car will noisily vent the excess pressure to atmosphere but on modern cars it will recycle the air back into the intake. Perhaps this is what I heard and why ANC is apparently only offered on the NX350. I turned the ANC back on for another drive and it did seem to eliminate these noises, but I will continue to experiment to gain more experience with the settings. I'm going to run with the ESE off for a little while to get used to it off, and then turn it back on at some point in the future to see if I can notice any change going back the other way. We'll see. I'm actually still getting used to my NX again, was away for a week on biz in Cincinatti and was driving a Camry hybrid while there. Drove a lot like the Camry Hybrid I once had except Wow, so much more efficient. I used to break out all the hyper mileage techniques to get that car over 40mpg, but this new one was easily getting over 60mpg (indicated anyway). Even when I drove it aggressively, I could not get the tank ave under 57mpg. It also reminded me how firm the NX suspension is in comparison, but while that Camry was generally smoother, it did not track as nice especially on sweeping highway curves. Also sucked having just FWD, annoying ![Sad](https://www.clublexus.com/forums/images/smilies/sad.gif)
I also took the opportunity to change my lane change flashes to 4, always found 3 not quite enough. Turned on the close and lock walk away function using the kick sensor instead of the button. Could be handy. I also played with the "control engine torque" to smooth out suspension (or words to that effect) but too soon to notice much difference. Maybe if some extra spare time lands in my lap I'll try to record differences with these settings on and off under same conditions to play back and see if there truly is much of a difference or not.
Coconut
09-30-21 06:33 PM
