Hi beam issues
2017 with the 3 lamp headlights and my hi beams simply don't work. The indicator light shows they are on, but are not. Car has the auto hi beam feature and that has no effect on the problem that I can see. If there are hi beam fuses or a relay, I certainly would like to know where they are located. The low beam fuses check out just fine. Any ideas for me?
Not sure but try turning off the auto hi beam setting.
How about if you pull the turn signal lever?
