NX - 2nd Gen (2022-current)
Low Driving Range Warning?
Old Today, 08:48 AM
chuckaluck66
5th Gear
chuckaluck66's Avatar
Default Low Driving Range Warning?
Is there a low gas setting where you are notified on either the Infotainment Screen (14") or HUD when the mileage range falls below a certain amount? I know there is the actual mileage meter as well as a light that comes on the dash but sometimes those aren't as easy to quickly spot. I've had this feature on other cars but haven't been able to figure one out for this one.
Old Today, 10:19 AM
AM123
AM123's Avatar
I couldn't find anything specified in the owner's manual regarding a low gas notification on the Infotainment Screen or HUD. It might be worth checking with your dealer for more detailed information. Based on my experience, the low fuel warning light typically comes on when the distance to empty is around 20 miles or less. For reference, the manual states that the "low fuel warning light indicates that remaining fuel is approximately 2.3 gallons (8.5 L, 1.9 Imp. gal.) or less."
Old Today, 11:26 AM
midcow3
midcow3's Avatar
Lightbulb
First to answer you question: (1) No HUD display of Low Fuel and (2) 14inch display (also 9.8 inch) only is the Current Fuel Consumption and History Fuel Consumption, no Low Gas screen)
You have several Low fuel warning items:
Gas Gauge ( green)
DTE (blue) -- This is displayed on the main screen if you have heads up display, otherwise you have to specify to display on multi-informational display.
Low Fuel ( red)
These should work for you in some combination so you don't run out of gas.
Some manual excerpts ( colored red, green, blue) are shown below. Good luck
YMMV,
MidCow3
Last edited by midcow3; Today at 11:44 AM. Reason: answer question, low level fuel text description about 2.3 gallon reserve
lexnxkm (Today)
Old Today, 11:50 AM
lexnxkm
lexnxkm's Avatar
Nice detailed response.
Pete7874
05-22-24 06:21 PM
Fithamoto
RC - 1st Gen (2015-present)
05-11-20 07:10 AM
ohiois350
10-29-12 09:45 AM
MajrNentsu
06-06-12 12:52 PM
lil' IS300
02-01-07 02:36 PM
Quick Reply: Low Driving Range Warning?
