Instability after 169km/h
Hello,
I would like a recommendation or explanation for my Lexus es300h. 2019
At a speed of over 160 km/h, the car has a very smooth movement, but I feel an instability.
I disabled all assist lines and it does the same. The feeling is that the wind is beating or turbulent.
Has anyone experienced the same?
Any advice is welcome🙏
Where are you feeling this? Through the steering wheel, the seat, the pedals, the floorboard or structure? You might have a tire that is failing, such as internal tread separation.
Am inlocuit anvelopele cu unele noi.
Se simte la nivel de masina. Este un efect pe care il simti cant treci pe langa un tir. Doar ca este mult mai lin.
"O plutire", instabilitate, Nu trebuie sa coerctrezi din volan directia.
Am verificat si telescoaple prin test autorizat.
Roughly translated:
"I replaced the tires with new ones.
It feels at the level of the car. It's an effect you feel when you pass a shot. It's just much smoother.
"A float", instability, You don't have to correct the direction from the steering wheel.
I also checked the telescopes through an authorized test."
It feels at the level of the car. It's an effect you feel when you pass a shot. It's just a lot smoother.
"A float", instability, You don't have to correct the steering wheel
we also checked the telescopes through an authorized test”.
LoLexCT200
CT 200h Model (2011-2017)
07-02-21 04:52 PM
asadsyed
ES - 6th Gen (2013-2018)
12
04-16-17 06:52 PM
