Toyota's legendary V8 has a problem
Take CCN's advice and change your coolant every 50,000 miles and forget about 10,000 mile oil changes go for half that. If you don't this will very likely be the result. I'm baffled to this day why Toyota didn't continue to evolve the UZ series engine there was zero reason to scrap it and go with the UR series.
I watched this one last night. Interesting that cylinder 7 is almost always the problem, sometimes cyl 5.
I don't remember the IS F ever having head gasket issues and some of those have high miles. I don't spend any time on the RC F board to see if anyone is having issues.
Oil changes for me are 5k or less and coolant will be done earlier than recommended. I just crossed 7k miles in my 500. It's going to take me a long time to reach 200k.
The UR is the evolution of the UZ, it's a modernized V8 with advanced tech using a similar bottom end and size from the same company.
Issues mentioned here are typical and why I've been also saying for years that IMO it doesn't matter what engine it is never go over 5k miles on oil and coolant lifespan should always assumed to be half. It's more about prevention of electrolytic corrosion than anything else due to all the dissimilar metals in car engines......
In its 229k mile life I never drained or flushed coolant on my ‘08 Tundra. I added coolant 1 time because the hot engine coolant light popped on one time while I was towing my car (just left home). Bought some coolant from Walmart, filled up the radiator then proceeded to tow 210 miles. Never touched it again after that. Never seen the light againNot great advice to follow but just my experience.
My mechanic told me never to go 10k OCIs in my LS460s years ago.
To be fair comparing the UR to UZ, nobody ever suggested that you could do 10k OCIs in the UZ, if everybody was running around doing 10k OCIs with UZ engines you have no idea what issues you would have.
My MB Mechanic also said no 10k OCIs in the Mercedes either. He said the valve cover issue I had at 50k miles was caused by clogged oil separators which wouldn't have happened with 5K OCIs. I did 10k in the S560 because I knew I wouldn't keep it where the LS460s I always entertained the idea I might. I will do 5k OCIs in the S580. I'm actually considering doing the in between 5k change myself just for giggles.
In general 10k OCIs are just not a good idea on an engine you want to keep for 100k+ mileage.
Even using 10k oil, I've always done 5k intervals. Every other oil change I would send samples to Blackstone, and they would always tell me what I suspected....around 7K is the "sweet spot". And if you have a turbocharged with DI, I would never go 10k because of fuel dilution in the oil
The ISF did have an issue with Valley plate leaking coolant, but I don't think it was anything serious.
Any DI will dilute the oil, Lexus is one of the worst because of the start to strategy to get the cats lit off. They start and spike rpm's high and dump fuel instead of using an SAI system, current Hondas have severe issues with fuel thinning the oil causing total failure
I do my oil changes every 5k on my Audi alongside some oil treatment which has improved it's oil burning. It's funny.. you will find people who SWEAR by doing the 10k oil changes on their Audi 2.0 and in the same breath they say it's "normal" to burn a quart every 2,000 miles.. no, it's not normal and if you did your oil changes every 5k from the start you wouldn't be burning oil.
I'm normally a follow the service manual type of person, but not when it comes to oil changes, transmission service and brake fluid. I follow the Severe service Intervals, which is why I'm pretty sure my Sienna is going to easily last over 200k
Tell me about it 🤣 I had a 2018 Si and the oil level would be higher in the morning until the fuel would burn off. You could smell it. My mechanic told me that he's getting quite a few 10th and 11th gen Accords and Civics in that need new engines. When I was there Friday for a tire rotation, a guy delivered a replacement Civic engine for yet another one that was blown
