regular coolant change to prevent blown head gasket
as mentioned by car care nut regarding the UR-series engines.
My LS460 had water pump leak at 55k miles.
Seems like I'm starting to see more V8 problem videos from him. Having 2 vehicles with the 4.6 in our household is concerning. Already had valley plate x2 repairs and now an oil leak on one of them. Not very happy. Hoping the oil leak is just valve cover gaskets. All manufacturers have their issues, but these are expensive repairs.
I think the valley plate may also be a contributor to this, when the plate leaks you get air pockets up high in the heads and that may result in hot spotting lifting the head. The area the failure is occurring is where I would expect to see it, middle of the head at the hottest part.....
Outside of that I really wonder if the head bolts are maintaining TQ or not, it would be such a shame if the final Toyota V8 ended its run and reputation as a failed design.
I'll personally be angry since the whole reason I bought these was to avoid problems and still have a resonantly powerful engine with high refinement. I like the uniquely smooth and laid back experience of the LS enough that an XF40 will be apart of my collection and I don't want this issue hanging over my head
Toyotas have had HG problems since corollas were rwd manual cars and before, the 3VZ 3.0L being the worst. The block decks would erode because of it on the worst ones and short blocks were being replaced under that campaign. The only new-ish thing here is that it's now happening on the V8's.
Marc780 (Yesterday)
This video is pretty darn clickbait, if you ask me. Did he test the coolant? Where did all those head gaskets come from?
So, a 200,000 mile engine has a problem - and that’s a trend?
His YT channel is in the business of making money, right? He isn't making those videos out of the goodness of their heart.
Kudos for him attaining the Master Tech status, but that does not make him 100% correct all the time.
Those farthest cyls are hottest. So.. Yea. Ordered some fresh coolant.
PS. Do not diss CCN. Do not.
It mostly was for that era, 5 and 7mge were pretty good, The 3B in the older landcruisers were very good...didn't make much heat or have much power though. At 200k miles I don't have many expectations from any vehicle either, they're usually a smoking oil leaking piece of crap.
https://www.youtube.com/watch?v=dfGTI0sWozc
Well alum heads, steel gasket.....add 2 volts and you know what happens. I just figured Toyota would have put a good enough coating on it and coolant to avoid this. Or something....
Marc780 (Yesterday)
Even though the cooling system is supposed to be sealed, coolant breakdown can happen long before the recommended change interval and you'd never know it. There is oil analysis for the engine but nothing even close for the coolant, and it is just as important. So the only smart thing to do is just change the coolant every 2 or 3 years (I use Toyota coolant 100% concentration plus distilled water, only). Even a simple drain and refill will do wonders for the long-term benefit of your cooling system.
texas008 (Today)
