Abs (front) sensor connector locations?
Hi everyone, i was just wondering if any of you might know where front abs sensor wiring connector (plugs) are located? I imagine the go into the engine bay somewhere, but I can't see where the wires pass???
any info or pics, would be great, thanks!
fab
fab
In the rear it goes through a grommet and into the body itself, but on the front surprisingly it's just out in the open. If you trace the wire to where it goes up you can probably peel it back enough to see. It's the same part for 2001-2007 Highlander and 2004-2009 RX as well despite the part no. differences.
fabchef (09-15-24)
Update, i put in a new batter and got a new abs sensor in there.
it's gotten better, the abs does kick in from time-to-time, but better than before.
i took the scan tool to it after, like before, the right(front) sensor (the new one), still has a drop, below about 6 km/h (drops to 0km/h). I also examined the tone ring, and looks good...no cracks or breaks in it.
so...if it's not the sensor or the tone ring...what else can be causing this???
ps...the brakes have been bleed.
fab
fab
