Timing belt, water pump and cam/crank seals
97 ES300 Timing belt kit
My regular mechanic who works out of his house on weekends thinks he won't have time to do replace my timing belt, water pump and cam/crank seals. TRQ on Youtube made an excellent DIY video from begining to end to replace it yourself. I watched the video.
I could do this job myself if I borrow a harmonic balancer pulley. He uses a oxyacatylene torch to get the bolt off. All I have is Map gas. Anyway what would you guess a Toyota delaership would charge for this job versus a regular mechanic. I've heard upwards of $2000. I only paid $2400 for the car 7 years ago. The car is started to get pretty rusty. Not sure if this is worth doing at this point? I have put a lot of work into it over the years. I worry that I could put on the new kit and after a weeks worth of work, it could still knock.
I don't really know. If they do, it ain't much, but it's the kinda thing where, if it's all apart, you just do it anyway for safe measure. The parts prices don't scare me, it's the potential dealership labor, versus car value. The video mentions the front crank pulley versus rear have different torque ratings which I'm pretty sure every mechanic, dealership or not is gonna completely ignore. There's only 1 local mechanic I trust and he's unavailable. If I can find someone to do it for $1300 and under, I may go for it.
So cut the job down to the necessities - which really are the belt and tensioner, tbh. Then it’s much more manageable.
Crank and cam seals are not a big job. However, in your case I'd just throw a belt on it because you said the car is rusty. To add, the crank pulley walked off in my case without any help (heat) so don't assume it will be a roadblock.
Cost? Indy said $2,200. Yeah...no on a car I paid $4500, so I did it myself, all parts replaced.
Oro, I noticed a leak on the timing belt side after I messed around with the alternator (I was trying to replace the belt but ended up not doing it because I couldn't get the alternator to drop down). But I kind of suspect that my disturbing that area led to a leak . Do you think that is possible? The area was already leaky but I think that I may have caused it to get worse to where it now leaks onto the floor.
The alternator has a locking bolt on the adjuster, the adjusting bolt, then a pivot bolt (the main attachment point). If all get loosened, then the alternator should (maybe with a bit of persuasion) swing loose to allow belt removal. It takes a bit of feeling around as the lowest bolts are difficult to see, IIRC.
I actually just changed that belt today. As Oro said make sure the locking bolt and pivot bolt are loosened. For me, I had to loosen the adjusting bolt ALOT in order to drop the alternator enough to get the new belt on. That adjuster bolt is very long so just loosen it alot. grab the alternator and yank it up and down. And I don't see how any of this could possible cause an oil leak.
The alternator did wiggle upwards a little, but not downwards, which is what confused me. There also seems to be some wiring under/behind the alternator and I was worried about crushing it.
Good info. I definitely loosened all 3 bolts, and I was sure that the adjuster was loose enough - but maybe I need to turn it a few more times. All bolts were loose enough to turn by hand.
trackball
Performance & Maintenance
18
08-12-10 12:10 PM
