Dashboard gauges work intermittently - 1998 GS 300
RPM, Speed odermeter, Temperature and Fuel gauges work intermittently.
Upon starting the car, there's accurate gauge readings, then while driving the RPM and Speed odermeter drop to zero, temperature gauge to cold and fuel gauge to "E" ( even with a full tank of gas).
Luckily the performance of the car isn't compromised but it is a mystery.
HELP......
HELP......
Pull the gauge cluster out, and check the connections. Also check:
* Fuse 6 on the driver side kick panel on the floor, behind the parking brake.
* Fuse 17 on the passenger side kick panel, by the passenger's right foot
* The 2nd fuse from the left on the top row of the engine room No. 1 fuse panel, in front of the battery
